Rear Bumpstop Issue - Page 2 - Second Generation Nissan Xterra Forums (2005+)
post #11 of 16 (permalink) Old 07-31-2018, 06:54 PM
2007 Midnight Blue ❌terra S
TerryD's Avatar
Originally Posted by Chase5Hart View Post
I noticed the same in my Radflos from PRG and will be going with longer radflos in the rear next time around, as for the timbren questions i talked to maxterra and they should be good up to 4” easy. He said he’s run them for 3 years with no problem
My shock combo seems to be about right. I actually had to slightly compress my Rads to get the bolt in them when I was assembling my rear suspension. And fully flexed, I've still got some up travel on the shocks left when I'm against the bumps. I think that'll be good since you'll need a little more up travel to compress both sides of the rear at the same time and also if I hit really hard, the Timbrens will have a chance to absorb a lot of that energy before the shocks reach their on-rod bumps.
Mildly Demented...
KT4OZ
Build Thread:
TerryD is offline
post #12 of 16 (permalink) Old 08-01-2018, 10:53 AM
2012 Lava Red ❌terra S
ZheKing's Avatar
Originally Posted by TerryD View Post
You need to trim those u-bolts for one thing. That length of them is probably all that's saved you from crushing a shock though.
He wouldn't be hitting the bump stop if the U-bolts were hitting something.
ZheKing is offline
post #13 of 16 (permalink) Old 08-01-2018, 11:04 AM
the u-bolts hit the bump stop....
post #14 of 16 (permalink) Old 08-01-2018, 11:17 AM
ZheKing's Avatar
I'm pretty sure the bump stop comes down in the middle of the u bolts, on the axle (or in the middle of the plate in this case since it's a flip kit), if it came down else where, that would defeat the purpose, but I reserve the right to be wrong, just seems like a bump stop would be lined up with the axle, and not off kilt on the bolts (even on a non flipped OEM configuration), as that would defeat the purpose.
ZheKing is offline
post #15 of 16 (permalink) Old 08-01-2018, 12:08 PM
when it flexes out, the u bolts hit first.
post #16 of 16 (permalink) Old 08-01-2018, 12:50 PM
2015 Glacier White ❌terra Pro-4X
Is that with the full SES kit? Meaning using the harder "puck" spacer also, or just the compressible parts of the kit?
prodragon4x is offline
