I Think my Shims are Cracking.... - Second Generation Nissan Xterra Forums (2005+)
 5Likes
post #1 of 17 (permalink) Old 03-14-2017, 03:16 PM Thread Starter
2007 Night Armor Xterra SE
Maverick's Avatar
So I've been noticing more clunking and popping from the back leaf springs than normal. I haven't been able to get it in the air and really take it apart and check the springs, but from what it looks like the pinion angle shim appears to be cracked in half, and since the middle of the shim is concave I believe this allows the leaf to 'rotate' a bit against the rear axle, since the cracked shim allows play.
I could be wrong, the popping and sounds could all just be because it's an OME/Dakar setup, and I've heard they're pretty noisy, but I wanted to see if anyone else has experienced anything similar.
Maverick is offline
post #2 of 17 (permalink) Old 03-14-2017, 03:24 PM
Your shim shouldn't be concave and your leafs shouldn't be rotating at all. If they are, you need to replace your center pin and tighten your u-bolts (loose u-bolts break center pins).
If your u-bolts are tight, check out your bushings. The OME bushings are absolute garbage.
post #3 of 17 (permalink) Old 03-14-2017, 03:43 PM
2006 Midnight Blue Xterra SE
dmski's Avatar
Literally happened to me. I had the crappy aluminum shims in the first go. I put the steel ones in and haven't had a problem since.
BillySpivitz likes this.
2006 Nissan Xterra:
dmski is offline
post #4 of 17 (permalink) Old 03-14-2017, 03:46 PM Thread Starter
Maverick's Avatar
Where do I get the steel ones from? My current ones are whatever NissTec gave me.
Also, what are the chances of NissTec replacing these Shims? The suspension was installed maybe 6 months ago. They shouldn't be cracked and falling apart. They should replace them with steel ones that won't fall apart.
Maverick is offline
post #5 of 17 (permalink) Old 03-14-2017, 04:22 PM
Super Moderator
Mr. Bills's Avatar
Where do I get the steel ones from. . .?
Most pinion angle shims on the market are made from cast aluminum or zinc alloy - with varying degrees of quality.
Nisstec typically supplies zinc alloy shims with their kits, and sells them separately for $44/pair + shipping (SKU N-RS).
However, Nisstec also sells steel shims for $49/pair + shipping (SKU N3DS):
Steel Axle Degree Shims - Nisstec Lifts: Nissan Lift Kits: XTerra Lift Kits, Frontier Lift Kits, Titan Lift Kits, Nissan Truck Lift Kits
You can get 3 degree billet aluminum shims from PRGProducts. Billet aluminum shims are less prone to cracking than shims made from cast aluminum. PRG shims are also a bit shorter than the shims supplied by Nisstec and conform better to the arch of the spring. I have been using them for several years with no issues. The price is $44/pair including shipping.
PRG Products
Another option is to try a local spring shop to see if they have steel shims the correct length, width and angle.
BCBrian likes this.
Mr. Bills is offline
post #6 of 17 (permalink) Old 03-14-2017, 04:42 PM Thread Starter
Maverick's Avatar
If NissTec won't replace them at cost or for free then I'll end up going with PRG (and possibly removing that NissTec sticker from my window).
I spent nearly $2500 on a suspension from them, they should fix this for free.
Maverick is offline
post #7 of 17 (permalink) Old 03-14-2017, 05:00 PM
I think I saw somewhere that PRG has steel shims too, they just are not listed on his website. I could be completely wrong though.
post #8 of 17 (permalink) Old 03-14-2017, 09:18 PM
2012 Avalanche White Xterra S
Hmm, I just bought a set (aluminum) from PRG and they say 4° FWIW.
fourxfunk is offline
post #9 of 17 (permalink) Old 03-14-2017, 09:24 PM
Snowtrout's Avatar
There's more than one angle of shim available.
Snowtrout is offline
post #10 of 17 (permalink) Old 03-14-2017, 10:09 PM
If you break a new aluminum shim, you are likely over or under-torquing the ubolts or center pins. Water and salt drip into the holes in the spring perches, which over time (as little as 1 year in my case) creates holes in the shim itself and completely degrades it from there.
Ask Greg at PRG about steel 3° shims. I need to call him up too.
mtnbiker49 is offline
