05 Driver Side Window Freaking Out - Second Generation Nissan Xterra Forums (2005+)
post #1 of 5 (permalink) Old 08-14-2013, 10:10 PM Thread Starter
2005 Super Black Xterra OR
Wanderer's Avatar
Not sure if this belongs in interior, exterior, or electrical...
So my drivers side window is starting to act up. Sometimes it wont roll up or down (completely dead). Other times it rolls down but when the window hits the bottom I can still hear the motor turning. I have to tap the up button to get it to stop. Other times it works just fine (but that is more and more infrequent). I am assuming I just need to replace the window regulator/mechanism thing, but maybe not... could this be an issue with the switch instead? I'm thinking the problem is around the sensor that tells the window it has finished rolling down, since it doesn't seem to be getting that signal. Any thoughts before I go pull the door apart?
Thanks
Nathan
Wanderer is offline
post #2 of 5 (permalink) Old 11-11-2013, 03:58 PM
2009 Night Armor Xterra Off Road
Slippery one's Avatar
Mine to. Well went down but will not go back up.
Keep the land and the water as clean or cleaner than it was when you arrived and take no more from it than what nature can replace.
Slippery one is offline
post #3 of 5 (permalink) Old 11-11-2013, 04:37 PM
2005
Mine has just started to randomly not want to roll back up. A few taps on the switch/door panel and it works fine.
My first thought is to clean the switch and make sure all connections are ok. A tap has always worked, so I haven't worried with taking the panel apart since I haven't had time.
GoldenX is offline
post #4 of 5 (permalink) Old 11-11-2013, 05:13 PM Thread Starter
Wanderer's Avatar
My problem turned out to be the window motor/regulator, not the switch bu tit wasn't. Replacing that is probably your best bet. I really thought it was the switch. It takes about an hour to replace the regulator, but is fairly easy if you read the instructions here: https://www.thenewx.org/forum/showthread.php?t=26631
And here: https://www.thenewx.org/forum/showthr...70#post1096770
I used this part (complete motor/regulator assembly): http://www.amazon.com/Dorman-741-348...-348+regulator
NOTE that that is for the front driver side door. The parts are different for different doors/sides. The replacement has been working fine since i put it in a month or two ago.
Wanderer is offline
post #5 of 5 (permalink) Old 11-13-2013, 04:13 AM
2005 s 4X2 s
xterramex's Avatar
its a 50/50 issue... either your switch is not working (had to replace mine 2nd time window problems came around) or the motor for the window is going bad.
you need an electrical auto shop to test the arm rest module and the motor to determine what needs to be replaced.
xterramex is offline
  Second Generation Nissan Xterra Forums (2005+) > Xterra Tech Topics > Interior
