UPDATED - iPad Mounted using RAM Tough Wedge (Pics) - Second Generation Nissan Xterra Forums (2005+)
post #1 of 13 (permalink) Old 05-17-2018, 06:44 PM Thread Starter
LVX
LVX's Avatar
UPDATE 5/26 - I had a chance to do some pretty decent off-roading with this setup and there was very little-to-no bouncing, so I'm very happy with it!
ORIGINAL POST - I've been using Gaia GPS for years as my main GPS. I've been wanting to mount my old iPad 2, but didn't want anything permanent, so I decided to try the RAM Mount Tough Wedge system. Bottom-line: I love it! I've just tested it with some light-to-semi-rough offroading and it's rock solid. You can really pump up the Tough Wedge to be really tight between the center console and the passenger seat. I went with the 6" extension, so it doesn't interfere with the shifter or drinks in the cup holder. What I really like about this system is how easy it is and that it's non-permanent...just depress the button to release the air and take it out. Too easy. If you're interested, here's the setup I'm using in my Xterra:
-- iPad 2 (have to have cellular in order to use GPS)
-- Beetle Defense iPad 2 case
-- RAM Tough Wedge with 1" ball
-- RAM Tough Wedge Expansion Pouch
-- RAM long length double socket arm for 1" ball
-- RAM Tab-Tite universal spring loaded cradle for 10" tablets with heavy duty cases
And, here are some pictures, so you can see how it comes together...
tcbrad98, eighty and go4WD like this.
LVX is offline
post #2 of 13 (permalink) Old 05-18-2018, 10:47 AM
That looks pretty sweet! Can the arm extend more over to the driver's side? Asking because I have a passenger when I'm out.. does it interfere with a passenger?
Thanks for sharing!
hybrid90 is offline
post #3 of 13 (permalink) Old 05-18-2018, 11:44 AM
IssacHunter's Avatar
Looks like someone finally found a use for all those cheap blood pressure cuffs lol.
So does it shake a lot offroading?
IssacHunter is offline
post #4 of 13 (permalink) Old 05-18-2018, 12:36 PM
2010 X
That's a nice setup. Do you figure once every app is carplay enabled there will be no need for an iPad?
eighty is online now
post #5 of 13 (permalink) Old 05-18-2018, 12:42 PM
Oh didn't noticed it was an actual pump. Thought it was the main mount.
OP - what does that pump thingamajig do? Pumps the tightness into the arm to hold the ipad?
Links to this mount?
hybrid90 is offline
post #6 of 13 (permalink) Old 05-18-2018, 12:48 PM
https://www.rammount.com/part/RAP-407BU
It's basically a blood pressure cuff bladder. Looking at the video for it this seems to be like a laptop soft zippered pouch where the bladder goes in and it has a ram attachment on a corner. You pump up the bladder inside the pouch and it applies lateral pressure to the center trim and seat to hold it tight. It's a pretty simple design I would have to say though not sure what prolonged use would do to your plastics.
If I had this though I think I would add a strip of velcro to the side of the bag and a strip of it to my center trim to hold it even better.
LVX likes this.
post #7 of 13 (permalink) Old 05-18-2018, 02:36 PM Thread Starter
LVX
LVX's Avatar
Thanks for sharing!
There are different sized arms you can get from RAM...the one I have is the 6" arm, so it has some ability to extend more to the driver's side. If you get a longer arm, you'll probably experience more bouncing during off-roading, if that matters to you. Otherwise, you could purchase different length arms from RAM and keep a couple on-hand for different types of driving (that's what I did...I purchased a shorter one for extreme off-roading, to help limit any bounciness).
I sat in the passenger seat and it didn't interfere with me at all, which was part of what I was looking for.
Hope this helps!
LVX is offline
post #8 of 13 (permalink) Old 05-18-2018, 02:41 PM
Hope this helps!
Thanks for the info!
hybrid90 is offline
post #9 of 13 (permalink) Old 05-18-2018, 02:46 PM Thread Starter
LVX
LVX's Avatar
Hi all - thought I'd try and consolidate some of the Q&A here:
- The pump is the additional RAM Tough Wedge Accessory insert. It's basically an air bladder with a hand pump (someone mentioned like a blood pressure cuff, that's a perfect analogy). It allows you to pump up the air bladder to create a real tight fit. It slides into the Tough Wedge softshell sleeve (alongside the original Tough Wedge hard plastic insert).
- I've only had a chance to test this a couple of times, but so far it's worked great. On the road and smooth dirt roads there's been no shaking. When I tried it on semi-rough off-roading, it shook a little, but nothing that bothered me too much. You can buy different length arms, so the longer the arm, the more shaking you'll experience. I purchased the 6" arm and the 2" arm, figuring I'll switch to the shorter arm when the off-roading gets too rough and the longer arm shakes too much.
- The nice thing about this setup, at least to me, is the customization of it: different length arms, can be moved around (slide the Tough Wedge back & forth to your best fit), non-permanent, let's me use a bigger screen with a full-size iPad, etc.
- As you can see from the pics, I switched out the OEM Rockford Fosgate head unit with a Kenwood unit that has Apple Carplay. If Apple ever allows the non-Apple apps to play through Apple Carplay, then I'd probably no longer use this setup and just use Gaia through Apple Carplay. But, I'm not holding my breath for this, as Apple is pretty restrictive (e.g., Waze and Google Maps are not allowed, only Apple Maps, via Carplay). Maybe Android users will have better luck.
Hope this helps!
LVX is offline
post #10 of 13 (permalink) Old 05-18-2018, 07:17 PM
2010 Xterra SE
tnelson's Avatar
On a slightly different subject...
When you have the iPad in the mount, it looks like it places the iPad well within the body of the X. How well does the GPS work there? Do it lock on to satellites without issue? I've never used GPS and am thinking of adding one, maybe an iPad, so your thoughts on how well it works. I would have guessed it had to be up near the window to work well?
Tom
tnelson is offline
  Second Generation Nissan Xterra Forums (2005+) > Xterra Tech Topics > Interior
