Well, the plastic nipple at the end of the cargo cover broke off.
It seems there is no easily replaceable parts and the rod with the end nipples does not slide out.
I do not think butt joining the broken faces with super glue or epoxy will hold with the tension.
Is the only alternative besides a new cargo cover some creative DIY fix?
My current thinking is a similar sized nut coupling with a threaded rod into the nut, and drill a hole into the broken end, epoxy the other end of the threaded rod into the hole.
