Dealer says It's My ECM, should I Believe Them! - Second Generation Nissan Xterra Forums (2005+)
post #1 of 18 (permalink) Old 06-24-2019, 01:46 PM Thread Starter
2010 Silver Lightning Xterra Off Road
TANSTAAFB's Avatar
I have a 2010 Off Road. A couple of times last week it didn't start right off, had to crank it over a couple of times before it would start but then ran fine. Then it was hard to start, finally caught, ran rough for a few seconds, died, wouldn't start again. Had it towed to my mechanic and they said they were unable to communicate with the ECM at all, no power to the fuel pump on prime or start and all fans came on as soon as key was turned to on. They found all the threads about the ECM relay which I've also looked at--the symptoms match my experience but the dealer says there aren't any relay recalls on my truck. They are still diagnosing but leaning towards needing a new ECM. I trust them as far as I can throw them so any advice from those in the know is greatly appreciated!
Sent from my Pixel 2 using Tapatalk
TANSTAAFB is offline
post #2 of 18 (permalink) Old 06-24-2019, 06:49 PM
pso
2006 Xterra X
How much does the dealership want to charge for changing the ECM? It may be worth it to change the ECM relay to see if that fixes your problem. If you don't want to do it yourself, what an independent garage would charge you to do it should be way less than what the dealership is likely to charge you to change the ECM.
pso is offline
post #3 of 18 (permalink) Old 06-24-2019, 06:56 PM Thread Starter
TANSTAAFB's Avatar
My lovely wife reminded me that we bought the extended warranty through our credit union and they're covering the ECM as well as a couple other things. So it's costing us a $50 deductible!
Brunnie likes this.
post #4 of 18 (permalink) Old 06-24-2019, 07:02 PM
That fan issue does sound like it could be the ECM, i've read on here about bad ecm's, something about white box vs black box or something.
mtnbound is offline
post #5 of 18 (permalink) Old 06-24-2019, 07:40 PM
2009 Xterra X
dude, don't know how to quickly link my thread but had the exact symptoms.
long story - new ECM corrected the problem at 1200 bucks or so...
I still have the old white model fuse tray and tried the eco relay swap with no luck. (And assume this played no role since the white tray is still on the truck.)\
received the same "cannot communicate with ECM", no prime, crank but no start, fan on as soon as i turn the key, shift linkage checked out and was not 'out of park'.
The only thing that i can attribute this to, is either a freak happening or had something to due with my positive battery cable worked loose to the point where the truck stalled on the highway. tightened everything back up and a week later the ECM was fried.
boyer is offline
post #6 of 18 (permalink) Old 06-24-2019, 07:40 PM
2009 Xterra X
and also had the security key lit up on the dash...
boyer is offline
post #7 of 18 (permalink) Old 06-24-2019, 08:13 PM
ChrisHaynesUSA's Avatar
please remember that your Xterras are 9/10 years old.
parts wear out and it is no surprise.
ChrisHaynesUSA is offline
post #8 of 18 (permalink) Old 06-24-2019, 08:27 PM Thread Starter
TANSTAAFB's Avatar
Of course! But when I'm reading that there's a known ECM relay issue that's about $10 to fix and the dealer (who I have zero experience with) says it's the ECM I'm gonna be a little wary. I care a lot less when my warranty covers it!
post #9 of 18 (permalink) Old 06-24-2019, 08:28 PM Thread Starter
TANSTAAFB's Avatar
Did you have any cat issues around the same time? Lots of folks on threads saying within a month or two of having ECM issues they had to replace the cats
post #10 of 18 (permalink) Old 06-30-2019, 10:44 AM Thread Starter
TANSTAAFB's Avatar
ECM was replaced under my extended warranty (as well as the rear hatch lock actuator so I don't have to lock it with the key every. Friggin. Time. I. Get. Out...), they re-ran all the diagnostics, no new codes once they could communicate with the ECM. Picked her up last Tuesday and all seemed good. Thursday night my wife comments that she seems to be idling a little rough (the X, not my wife), Friday morning had to hit the key twice but started, Friday afternoon had to crank and crank but finally started up. Got her back to the dealership without another tow but they won't be able to look until tomorrow. Any ideas what now? No warning lights are on. Didn't pay attention to whether the fans were coming on this time. Very frustrated and ready to have the old mountain goat back (again, the X not my wife ) cuz the Rogue they gave me for a loaner just ain't cuttin it.
Nake likes this.
