AC not Working, Replaced Resistor, then Blower Motor, checked Fuse - Second Generation Nissan Xterra Forums (2005+)
post #1 of 20 (permalink) Old 05-31-2019, 07:24 PM Thread Starter
Hello, i have a second gen 06 S. My ac went out last week, I've replaced the resistor a few times so ordered one and replaced it. Still didnt work, so i replaced blower motor, and checked the fuse. Still no luck. Not sure what else could be the problem. Has anyone else had a similar issue? Any suggestions would be greatly appreciated
Diddy is offline
post #2 of 20 (permalink) Old 05-31-2019, 09:17 PM
Assuming the compressor is not running, step 1 should have been "Have the refrigerant charge checked". If that was good then proceed to other steps.
Brunnie is offline
post #3 of 20 (permalink) Old 06-01-2019, 01:13 AM
satown210's Avatar
A/C doesn't work doesn't exactly say whats wrong. Is the blower not working? Is the blower working but it isn't cold etc etc?
satown210 is online now
post #4 of 20 (permalink) Old 06-01-2019, 09:01 AM Thread Starter
Right, so let me explain some more. 1,2,3,4 all do not work when trying to turn air on. The little AC light comes on to show its engaged when going from 0 to any number. I can hear the compressor kick on. When im on the highway i can feel that cool air coming through a bit but the fan isnt spinning. So as states before replaced resistor and motor but still no luck. I figured maybe i got a faulty part, so tried swapping out resistors and trying the old one again, and still cant get that fan to turn.
Diddy is offline
post #5 of 20 (permalink) Old 06-01-2019, 10:34 AM
OK, much better details. Does the fan work when the controls are in the heater positions? Does it work when you want the defroster on? Basically to me it sounds like the blower motor has died, but I'd try various combinations before blaming the A/C section.
Brunnie is offline
post #6 of 20 (permalink) Old 06-01-2019, 10:35 AM
2012 Night Armor Xterra S 4x4
BlackbirdSR71's Avatar
You might have leaked out all the refrigerant...check that first. On a 13 y/o Xterra - this could have happened by now ?
Brunnie likes this.
BlackbirdSR71 is offline
post #7 of 20 (permalink) Old 06-01-2019, 12:38 PM Thread Starter
No blower on heat either. The blower i took out was pretty damn stiff comared to the new one i put in. The fans not spinning on any speed heat or cold. Brand new resistor and motor.
Diddy is offline
post #8 of 20 (permalink) Old 06-01-2019, 01:41 PM
Can you hook the new motor directly to 12 volts and see if it spins? If it does, then it isn't a motor problem. If it doesn't, you've found your problem.
Brunnie is offline
post #9 of 20 (permalink) Old 06-01-2019, 10:54 PM
pso
2006 Xterra X
If the old motor was siezed and not turning, it could have pulled enough current to fry the fan speed selector switch (front blower switch).
It is highly likely that your new motor will spin when connected directly to 12V. Please use a voltmeter/DVM to check the two motor wires. With the vehicle turned off and the switch set to 4, one of the wires (blue?) should show low resistance (under 10 Ohms) to chassis. If the DVM reads something higher than 10 Ohms, either one of the connectors is not plugged in correctly or the switch is fried. With the vehicle on and the switch set to 4, the other wire (white/green) should give you your battery voltage (12 to 14V). If you do not get the battery voltage, either the two fuses (labeled 24 and 27 on page MTC-36) or the Front Blower Motor Relay are bad.
It would be very helpful for you to download the Factory Service manual from the link below. There is a diagnostic table on page 30 of the MTC section (mtc.pdf) followed by the schematics and wiring diagrams for the HVAC system.
https://nicoclub.com/archives/nissan...e-manuals.html
pso is offline
post #10 of 20 (permalink) Old 06-02-2019, 12:48 AM
satown210's Avatar
Freon has nothing to do with the blower motor not working.
The only thing left after blower motor, resistor, and fuses is the fan selector switch.
