Please Help Me Find What Part This Is - Second Generation Nissan Xterra Forums (2005+)
  • 2 Post By General_Tarfun
post #1 of 7 (permalink) Old 05-12-2019, 03:05 PM Thread Starter
2014 Xterra
Hi! I am finishing up an HIG retrofit. After I made all the connections, I tested out the lights and found that the high and low beams were reversed. After a little searching, I found that I may need to switch the pins around that connect to the stock harness, similar to this video:
When trying to remove these pins to switch them around, I ended up busting one. The local auto parts store did not have a suitable replacement. Can anyone point me in the right direction on what part this is, exactly, so that I can order it and finally finish up my project? Many thanks for the help.
fwadam is offline
post #2 of 7 (permalink) Old 05-13-2019, 02:59 AM
2011 Xterra S 4WD
I don't see any pictures. But, maybe you can jump the two wires without going through the socket.
Leonard4X4 is offline
post #3 of 7 (permalink) Old 05-13-2019, 10:06 AM
Originally Posted by fwadam View Post
Hi! I am finishing up an HIG retrofit. After I made all the connections, I tested out the lights and found that the high and low beams were reversed. After a little searching, I found that I may need to switch the pins around that connect to the stock harness, similar to this video: https://www.youtube.com/watch?v=dkg9iAiqyCw
Hello local Pick-a-Part.
Brunnie is offline
post #4 of 7 (permalink) Old 05-13-2019, 10:33 AM
The part you need is a male 9007 Headlight socket with pigtails, just cut off the one you messed up and splice this one in. Technically the pins can be replaced but unless you have professional tool for making the pin to wire connection it's a better idea to just buy it with that already done.
Brunnie and Leonard4X4 like this.
post #5 of 7 (permalink) Old 05-13-2019, 02:25 PM
2012 Lava Red ❌terra S
ZheKing's Avatar
If the pins are fine I wouldn't even cut it off. I'd finish depinning it and repin in a new blank one.
ZheKing is offline
post #6 of 7 (permalink) Old 05-13-2019, 02:38 PM
OP said he broke one off.
post #7 of 7 (permalink) Old 05-14-2019, 11:44 AM
ZheKing's Avatar
i read it as he busted the plastic part. I read it wrong.
ZheKing is offline
Help Me Find a Part for Cooling System HashX General Xterra 6 10-25-2015 11:41 AM
Aftermarket Part Find: Stock Recovery Points Option kmedina941 Online Finds 9 09-03-2015 08:54 AM
Ranking of 50 states by Square Miles ChrisHaynesUSA Road Trips 7 01-03-2015 12:10 PM
Glossary usmc xterra Brakes, Tires and Wheels 16 08-27-2010 02:10 AM
U-Joint Part #'s masscomguru Powertrain & Driveline 14 10-22-2009 12:53 PM
