Suggestion on Fog Light Options - Page 3 - Second Generation Nissan Xterra Forums (2005+)
 12Likes
post #21 of 32 (permalink) Old 10-16-2018, 07:16 AM
2014 Lava Red Xterra S
Billoftt's Avatar
Originally Posted by MartinX View Post
The Morimoto are not “bulbs”, but whole assemblies. They replace the existing stock foglights completely.
https://www.theretrofitsource.com/ni...to-xb-led.html
https://www.amazon.com/Nissan-Xterra.../dp/B0731LLV59
https://www.thenewx.org/forum/23-ext...og-lights.html
Google: morimoto led fog light xterra
I see. When I was searching the web I actually found the Morimoto 9007 LED headlight bulb. I wonder if anyone here has used those yet.
Billoftt is offline
post #22 of 32 (permalink) Old 10-16-2018, 10:30 AM
2012 Lava Red ❌terra S
ZheKing's Avatar
Originally Posted by lleung1980 View Post
what is the model name/number of your Morimoto light?
Originally Posted by Billoftt View Post
Tell me more about your Morimoto bulbs. I want something better but I do not want the LED "scatter-bombs" that everyone else has.
They are the XB flats. They are able to be aimed as well.
Nissan (Flat): XB LED - Fog Lights from Morimoto HID
It's kind of a dumpy video in my drive way since this was after I had just aimed my HID's using the garage door, but they were definitely worth it, especially for the simple plug and play aspect.
ZheKing is offline
post #23 of 32 (permalink) Old 03-02-2019, 05:09 PM Thread Starter
2015 Xterra S
lleung1980's Avatar
I have a S model, if I get the Morimoto and the stalk. What else do I need to install the light? Do I need new hardware?
2015 S model 4WD Glacier White
lleung1980 is offline
post #24 of 32 (permalink) Old 03-02-2019, 08:56 PM
2012 Xterra X
You will need the brackets that the fog lights bolt to.
Battousaited is offline
post #25 of 32 (permalink) Old 03-04-2019, 02:22 PM
RGQ
When I got my X (06-S) front lighting was less than desirable. With that I did the following that resulted in much improved, very adequate lighting at low cost.
First thing I did was to clean/revitalize existing OEM headlight lenses as they were faded/sun damaged. I used a kit from 3M as I already had it . There are numerous products and U-tube vids out there for reference. Goal is to end up with clear plastic again. Some improvement was gained from this action.
Next I ordered and installed new Halogen bulbs. Replaced the OEMs with “Philips Crystal Ultra Vision” bulbs. Bought them on E-Bay for less than $30 and installed them in less than 10 minutes. Major improvement.
I still wanted to take advantage of the stock bumper mount location for fog lights but didn’t want to spend $200+ dollars for an OEM kit. So I ordered an aftermarket fog lamp kit from A1auto.com for about $60. Kit included all necessary parts, install was fairly simple and it comes with a lifetime warranty. Instructions were very generic, but provided enough info to get the job done. Most difficulty came in finding a switched power source that is easy to get to. I used the rear passenger power plug located by the cup holder.
End result was major improvement in lighting without going the HID/LED route
RGQ is offline
post #26 of 32 (permalink) Old 03-04-2019, 04:38 PM
2011 Night Armor ❌terra Pro-4X
I’m running katana led headlights and STEDI led fogs, love them
I know what this man needs, bring me the bourbon. -Cole Kehm
emtmark is offline
post #27 of 32 (permalink) Old 03-07-2019, 02:15 AM Thread Starter
2015 Xterra S
lleung1980's Avatar
Do you happen to have the part number or photo?
post #28 of 32 (permalink) Old 03-25-2019, 07:07 PM Thread Starter
2015 Xterra S
lleung1980's Avatar
I'm installing the Morimoto kit, Can someone confirm this stalk would work for my 2015 S model?
P/N 25540-CB61E
post #29 of 32 (permalink) Old 03-25-2019, 07:14 PM
P/N 25540-EA00A
No. You need 25540-ET11A.
MartinX is online now
post #30 of 32 (permalink) Old 04-07-2019, 03:18 PM
2008 Red Alert Xterra
Are the wires there on the 2008 model?
heavymetaldarts is offline
