2005, Bad Engine Knock/Death Noise? - Second Generation Nissan Xterra Forums (2005+)
post #1 of 10 (permalink) Old 05-21-2019, 02:25 PM Thread Starter
2005 Xterra
Angry 2005, Bad Engine Knock/Death Noise?
I had a previous thread in which I thought the timing chain had gone.
I have a 2005 off-road, 2wd, automatic, 150k miles.
family and I were driving 70mph down highway, suddenly I have no power to accelerate. Look down gauges are dead. So i pull over. wont start.
I had just had crankshaft sensor and both camshaft sensors replaced a month prior to this because it kept stalling on her. I finally had a friend come to get her and kids and they tried to jump it off. Made a god awful noise like a motorboat almost and died within seconds.
Towed it home. Sat for a month plus ( we seperated and legal issues, so been busy ). Pulled codes, got P0011 and then a couple of cat codes. replaced the camshaft on passenger side and nothing.
put my buddy's redtop in it (it wouldnt turn over on a jump either). and again...god awful noise, clicking, banging, dies.
I did check oil and it was dry (even though it was changed 2 weeks before it died). So i did put a few quarts in to get it to read before doing this.
I am MAYBE going to sell it, but really wanted to utilize the knowledge here on the site to try to save my investment.
Here is a vid of noise
Debago is offline
post #2 of 10 (permalink) Old 05-21-2019, 02:51 PM
Well then...
2011 Avalanche White ❌terra X
ccg1018's Avatar
2005, bad engine knock/death noise?
You should have kept the original thread. We would have kept replying.
Okay so, that noise could be one of many things. How mechanically inclined are you? Is there oil residue anywhere? Is the oil filter on tight? You may have thrown a bearing from lack of lubrication.
I would do a compression test and depending on the result remove the oil pain and check the rods for any play. An engine is running about $1,700 on eBay right now.
ccg1018 is offline
post #3 of 10 (permalink) Old 05-21-2019, 02:57 PM
Adam12SD's Avatar
Wow. I read your other thread and assumed it was the camshaft sensor... Sorry, I didn't know the extent of the rough running or sounds.
It honestly sounds like a bent rod to me, meaning engine rebuild or replacement. Good luck to you brother.
Adam12SD is online now
post #4 of 10 (permalink) Old 05-21-2019, 03:02 PM Thread Starter
2005 Xterra
Thanks guys.
Ebay engines are just junkyard motors from what I've seen. The pull a part yard here has 3-4 motors in right now. I just need to find someone to help pull it I suppose.
So looks like the verdict is that it is toast for sure; motor wise.
ccg1018 - there was oil reside around the oil residue, but I havent looked around too much more. I can take the oil pan off tomorrow after work, but if it needs a rebuild I wont bother with it.
Debago is offline
post #5 of 10 (permalink) Old 05-21-2019, 03:06 PM
Adam12SD's Avatar
Originally Posted by Debago View Post
Thanks guys.
I would definitely do a little more investigating before pulling a motor, though. Showed it to a buddy of mine that's a mechanic and he says just from sounds alone it sounds like a smashed bearing or bent rod too.
A compression test would tell you more. Maybe have someone take a look in person. Jeez, I'd be quite frustrated too.
post #6 of 10 (permalink) Old 05-21-2019, 03:35 PM Thread Starter
2005 Xterra
Thanks, I appreciate it!
Debago is offline
post #7 of 10 (permalink) Old 05-21-2019, 03:45 PM
pso
2006 Xterra X
From the small amount of reading I have done, it is possible to drop in an engine from a newer vehicle, say from a 2014 or a 2015. I think some of the parts need to be changed but I don't recall what they were (sensors?). The price for the newer engines didn't seem significantly higher than for a 2005 or 2006 engine.
I have been considering the possibility of having to do an engine replacement. The prices for a rebuild were up over $3000 where I am. I don't recall if that included installation.
Best of luck.
pso is offline
post #8 of 10 (permalink) Old 05-21-2019, 05:58 PM
2006 Storm Gray Frontier SE
malleusdei321's Avatar
Sounds like my engine when I spun two rod bearings and had to rebuild it. If you're able to rebuild it yourself you should be able to do it for around $1,500, that's how much I spent when my father and I rebuilt it and I replaced everything that I could. I'm also sending you a pm about a engine.
malleusdei321 is offline
post #9 of 10 (permalink) Old 05-21-2019, 06:07 PM
I know it's not a super high quality sound recording but the noises sound like top end to me? The last motor I had with lower end problems produced a deeper sounding knock vs that clattering noise.
General_Tarfun is online now
post #10 of 10 (permalink) Old 05-22-2019, 08:45 AM Thread Starter
2005 Xterra
Thanks! very interested. Just need to wait a few weeks right now. Plus we are about 9-10 hours apart lol.
Also,
I will try to get a better video today after work/gym.
Debago is offline
Scratchy/Raspy Noise When Turning Over Engine Fresh Prince Powertrain & Driveline 6 11-08-2016 08:14 PM
Cold Engine Valve Train Noise trwinship Powertrain & Driveline 20 09-18-2014 07:29 AM
Help me find A/C controls dragonplayboy Interior 8 01-17-2011 11:46 AM
Glossary usmc xterra Brakes, Tires and Wheels 16 08-27-2010 02:10 AM
Clicking Noise from Engine Compartment??? all2surreal General Xterra 7 01-24-2007 08:00 PM
