My Overdrive seems Underdriven - Second Generation Nissan Xterra Forums (2005+)
 6Likes
  • 1 Post By jsexton
  • 2 Post By satown210
  • 2 Post By 29erClan
  • 1 Post By ccg1018
post #1 of 9 (permalink) Old 05-16-2019, 09:34 PM Thread Starter
I’m on my second Extera, first one was an ‘04, this one is an ‘07 with 152,000 miles, both are automatics, my overdrive gear was slipping in and out of neutral, I can’t check the trans fluid due to it’s a sealed unit, anyone hear of this and is there a solution or is my tranny fried, I can still drive it with the overdrive switched off,
Jsewar is offline
post #2 of 9 (permalink) Old 05-16-2019, 09:38 PM
545
2005 Xterra
This post is odd, but if you do have an automatic 2007 Xterra, then you do not have a sealed transmission. Bring it to a shop and have them take a look.
545 is offline
post #3 of 9 (permalink) Old 05-16-2019, 10:33 PM Thread Starter
There’s a cap on the dipstick tube so there’s no dipstick and it appears factory looking I took it to a garage and they said it appears to be an internal mechanical problem, I’m going to the dealer to get a second opinion
Jsewar is offline
post #4 of 9 (permalink) Old 05-16-2019, 11:42 PM
Take the bolt out, pull on that cap. Its a dipstick.
mtnbound likes this.
You are free to choose, but you are not free from the consequence of your choice.
post #5 of 9 (permalink) Old 05-17-2019, 12:07 AM
satown210's Avatar
The Extera might not have a dipstick but the Xterra does.
mtnbound and ccg1018 like this.
satown210 is offline
post #6 of 9 (permalink) Old 05-17-2019, 12:15 AM
2011 Night Armor Xterra Pro4X
Easy fellas,.. English is obviously not his native language.
I hope he does not have the feared SMOD
2011 Pro4X, NightArmor, w/2015 Pro4X wheels
Every day.. Men who will follow orders to kill you, exercise. Do you?
bluez is offline
post #7 of 9 (permalink) Old 05-17-2019, 12:52 AM
satown210's Avatar
If it shifting except for OD I'd imagine that he has a mechanical or electrical issue. 152K, unknown maint or towing. I could see it failing.....
post #8 of 9 (permalink) Old 05-17-2019, 08:33 AM
Would you describe it as "hunting" or "fluttery" when it's trying to shift up into overdrive? It sounds a lot like what I saw recently. Hit the O/D Off button and it behaved just fine locked at 4th.
First, like others mentioned, check the dipstick. You need a 10mm socket and extension to get it open, make sure you turn the bolt ring 180 to the front for a good reading. You need to check it running, warmed up, and on pretty flat ground. Check the level and condition. (SMOD)
Get a copy of the FSM. FWD.pdf is the index.
Find @Mr.Bills post on SMOD radiator part numbers and compare yours to it.
I can't tell you what's wrong with yours, but the 06 trans controller in the attached pics had similar O/D symptoms and is now running much smoother with new solenoids. I also scrubbed the corrosion off the traces with an old tooth brush, but none of the leads to the solenoids needed repair. (Some here have soldered splints with good luck.)
It took me 2 days to complete at my slow pace but was only about 4-5 hours of actual labor. The original solenoids went about 190k miles. Shifts fairly firm and quick now.
With luck yours may just be a bit low on fluid.
jsexton and ccg1018 like this.
post #9 of 9 (permalink) Old 05-17-2019, 10:41 AM
Well then...
2011 Avalanche White ❌terra X
ccg1018's Avatar
Im going to bookmark this thread for future reference. I can never stare just how helpful everyone is here.
OP, I hope everything turns out alright with your transmission.
bluez likes this.
ccg1018 is offline
Can't Disable Overdrive? John Wasserplatz Powertrain & Driveline 13 10-02-2017 11:53 AM
Overdrive Alternator Pulley CGS Electrical 0 04-14-2013 09:51 PM
MPG, Overdrive Pro4xnyc Powertrain & Driveline 5 02-15-2012 04:10 PM
Vibration Overdrive Issue fishhead202 Powertrain & Driveline 38 03-17-2011 08:54 PM
Overdrive vibration Iroctd Powertrain & Driveline 12 01-20-2011 02:46 PM
