Pro4X Vs S Trim - What are the Mechanical Differences? - Second Generation Nissan Xterra Forums (2005+)
 56Likes
post #1 of 30 (permalink) Old 04-29-2019, 02:38 PM Thread Starter
2011 Xterra S 4WD
Question Pro4X Vs S Trim - What are the Mechanical Differences?
I would like to be educated more about the mechanical and tech differences between the 2011 Pro4X and the S 4WD. I am sure this has been discussed before. I just can't find a thread. Thanks to all in advance.
Leonard4X4 is offline
post #2 of 30 (permalink) Old 04-29-2019, 02:51 PM
Shocks, tire size from the factory, boob lights, rear diff locker, fold flat passenger seat, seat covering material, floor mats, stereo
bluez, Adam12SD and Leonard4X4 like this.
post #3 of 30 (permalink) Old 04-29-2019, 03:27 PM
2006 Storm Gray Frontier OR KC NISMO 4x4 6MT
mrpulldown's Avatar
The only mechanical difference is the push button rear locker. The rest of it is all bolt on and trim differences. The Pro4x gets you a lot bundled goodies that the base models doesn't.
mrpulldown is offline
post #4 of 30 (permalink) Old 04-29-2019, 03:31 PM
2013 Cayenne Red Xterra S
Apples491's Avatar
All of the above, plus ...
- On the autos, the Pro-4x gets Hill Descent Control.
- On the 6 speed, it gets Clutch Bypass.
- Slightly different wheel styling.
- Pro-4x gets a Rockford Fosgate stereo with sub and amp. For the 2014-15 MYs they had navigation and Bluetooth.
bluez, NWCoffeeGuy and Leonard4X4 like this.
Apples491 is offline
post #5 of 30 (permalink) Old 04-29-2019, 03:48 PM
Let's not forget the mechanical difference of gear ratio's and the C200 axle on the S vs. the M226 on the P4X
IM1RU is offline
post #6 of 30 (permalink) Old 04-29-2019, 03:51 PM
Unless the S has a manual tranny, M226 with yet another ratio.
jcco, morrisjw2 and Leonard4X4 like this.
post #7 of 30 (permalink) Old 04-29-2019, 04:04 PM
Yes, that too.
Leonard4X4 likes this.
IM1RU is offline
post #8 of 30 (permalink) Old 04-29-2019, 05:51 PM Thread Starter
2011 Xterra S 4WD
Longboardr,
Mine is a 2011 S 4WD. I think I have the rear diff lockers. When I engage 4LO it turns VDC off, because the rear diff is locked. Am I getting this right???
post #9 of 30 (permalink) Old 04-29-2019, 06:06 PM
Longboardr,
Nope, no locker on an S as it came from the factory. If you had a locker it would be a push button independent of the 4wd selector.
bluez and Leonard4X4 like this.
post #10 of 30 (permalink) Old 04-29-2019, 06:09 PM
LBX
LBX's Avatar
Don't forget about the white gauge faces! (maybe not quite mechanical, mechanical)
Leonard4X4 and kolsky like this.
LBX is offline
OK Honest discussion 2015 4 Runner vs 2015 Xterra (espc. Pro4X) bluez Off Topic 14 04-27-2019 10:57 PM
Offset for Stock Steel Wheels for the X Trim Level Xtra99 Brakes, Tires and Wheels 3 10-30-2018 05:24 PM
How-to: Convert Manual Side Mirrors to Power (Updated, Tons of Pics) iamamused How-to's 27 01-13-2018 10:59 PM
Rigid D2s in Pro4X Air Dam shaboo Electrical 16 08-27-2014 04:55 PM
Newbie question about trim model leung19 General Xterra 10 05-12-2010 02:12 AM
