Loud Clicking from Front of Engine - Page 3 - Second Generation Nissan Xterra Forums (2005+)
 11Likes
post #21 of 35 (permalink) Old 04-19-2019, 07:10 PM
dang man, i mean if you have to drive it you have to drive it...
the concern at this point is that that chain comes off the pulley or skips a tooth and then the timing gets thrown off and bends a valve/ messes up the piston/ head.
and then your looking at not just fixing the timing chains but a full rebuild/ engine swap.
best of luck!
bluez likes this.
mtnbound is offline
post #22 of 35 (permalink) Old 04-19-2019, 07:29 PM
We canít give magical answers. You asked about noise and have come to a conclusion of what it most likely is.
Continuing to drive the truck is a gamble. You know that.
My life seems to work the way yours has lately. I feel for ya. I wouldnít call myself a sh1t magnet, but boy does it come in spades sometimes.
Thatís life I suppose....
Canít your bank get your back and replace some funds? If itís fraud? Iíd sure be asking.
No one to carpool with? Bus? Bicycle?
Do what you need to do. Be aware though that when the chain grenades itís going to be a whole lot more expensive.
Best of luck. If my magic wand still worked Iíd wave it your way for sure......
bluez likes this.
MartinX is offline
post #23 of 35 (permalink) Old 04-19-2019, 10:12 PM
545
2005 Xterra
best of luck!
Non interference engine, so no bent valves, but if a chain comes off it's gonna be bad
OP, that has to be the main timing chain if it's that much noise. You will regret it if it comes off or breaks. Park it.
bluez likes this.
545 is offline
post #24 of 35 (permalink) Old 04-19-2019, 10:32 PM
That sounds worse than just worn tensioners, more like the tensioner has broken off and the chain is just riding on the stud. Like others have said if the chain breaks/derails it will cost more for repair obviously but at this point you're looking at 1.5-2k in repairs (Nissan dealership cost) or $400-$600 in just parts if you can do the work anyway for just the chains/guides.
If that's more than you want to put into it I'd say drive it if you have to but take it as easy as possible and be prepared for a possible breakdown that will require some kind of a tow and a ride for you.
If you really want to repair the truck you should park it and tow it to where ever the work will be performed ideally. I've noticed a lot of shops are offering repair financing now, I'm sure the terms aren't great but it can get you through to getting paid at least. Most shops will give you a tow if they are going to be performing the repair work so that would at least get you out of there. The dealer that did my timing chains threw in a loaner vehicle after I asked for one.
bluez likes this.
post #25 of 35 (permalink) Old 04-20-2019, 07:38 PM
Does anyone know if the tensioners on these motors are pressurized from engine oil pressure? if so, a can of Marvel Mystery Oil might get him down the road.
grrrant is offline
post #26 of 35 (permalink) Old 04-20-2019, 08:45 PM
545
2005 Xterra
The primary is, as well as spring. The secondaries, not so sure, oil does go through them, so I think yes as well.
I don't suggest any oil additives
545 is offline
post #27 of 35 (permalink) Old 04-20-2019, 09:44 PM
Does the fan wobble? Could be very worn out bearings on the fan clutch pulley.
ĒYou are free to choose, but you are not free from the consequence of your choice.Ē
post #28 of 35 (permalink) Old 04-20-2019, 10:28 PM
2006 Knight Armor Xterra SE
that other video sounds like the main chain slapping due to a broken tensioner shoe. the timing chain case on the left side has an acces port to see. a few 10mm bolts will let you see what's going on. its definitely a gamble taking a drive on that though.
IntellectualRedneck is offline
post #29 of 35 (permalink) Old 04-21-2019, 07:14 PM Thread Starter
2005 Avalanche White Xterra S 6MT
PebblePimp's Avatar
I took the belt completely off. Still sounded like an early 90s 12 valve Cummins.
jsexton likes this.
PebblePimp is offline
post #30 of 35 (permalink) Old 04-21-2019, 07:24 PM Thread Starter
PebblePimp's Avatar
I tried to post an update yesterday, but cell signal was extra crappy.
We reached a spot where my morning tour hand could pick me up & drop me off at the hotel. And, 2 days before the noise started, my dad bought a car hauler. I was starting to freak out about how i was going to commute to work. There is no public transportation in BFE, Oklahoma. Dad picked it up last night & met me in OKC since my relief hand lives there. I bought him a couple beers & lunch at Twin Peaks. (I take care of my hands. Lol) I’m probably going to have the Nissan dealership do it, just because they can get it done faster than I can. Plus, I gotta go back to E. OK this week for another job that’s 24 hour service (2x the money for me). I can make that money back in a couple of days. So, things are starting to look up.
The Top Mileage Thread - Lead: 350,000 Old Navy General Xterra 459 Yesterday 05:41 PM
How-to: Correct and More Problems if Heater Blows Cold at Idle or No Heat jeff_redx Powertrain & Driveline 35 02-10-2019 01:42 PM
How-to: 2wd to 4x4 Conversion USMMA11NC How-to's 74 01-29-2018 02:53 PM
Another Noise - Metallic Sounding - Coming from Front of Engine twhjelmgren28 Powertrain & Driveline 6 02-16-2016 08:38 AM
Clicking Noise from Engine Compartment??? all2surreal General Xterra 7 01-24-2007 08:00 PM
