4x4 Indicator Blinks - Second Generation Nissan Xterra Forums (2005+)
post #1 of 27 (permalink) Old 03-25-2019, 10:55 AM Thread Starter
2007 Pathfinder
Unhappy 4x4 Indicator Blinks
Hello all,
I have 2007 R51 Pathfinder 2.5, 175k km. I have an issue that few mechanics are not able to fix for almost 2 years (I'm working outside of the country and I wasn't using the car).
My 4x4 Indicator blinks (not whole, but just front wheels and the square in middle) almost non stop without any reason:
I can't upload video yet, but this is the indicator that shows the driving mode AUTO/4H/2L. In Xterra this is located in Tachometers circle)
1. Transfer case was replaced (second hand)
2. Transfer case CU was changed (then reverted back to mine)
3. All cables from Transfer case to Transfer case CU are checked
4. The position of all wheels is correct
5. No error in ECU
6. ABS is ok
7. EPS is ok
Other changes(made before the problem)
ECU was reprogrammed to disable DPF.
I have no idea what to do. I'm writing in Xterra forum, because I believe that they are almost same cars.
Last mechanic said that this is probably some software issue (He spent 4 months changing parts, checking the cables, etc.).
Anyone having this issue?
kivanov is offline
post #2 of 27 (permalink) Old 03-25-2019, 12:08 PM
JNR
JNR's Avatar
Mine did when one of the harnesses came off the clip and rubbed on DS...was partially my fault when I installed LT headers, but even so, only thing preventing that is a plastic retainer that will dry out and fail over time, I bet...not saying that is likely, just possible. Bad spot for the harness, really.
JNR is offline
post #3 of 27 (permalink) Old 03-25-2019, 05:21 PM
Possibly a bad neutral safety switch, but I'd think it would only be an issue going into 4lo if it were that.
No ABS, Brake, or VDC lights lit up on the dash correct?
post #4 of 27 (permalink) Old 03-25-2019, 08:54 PM
2011 Night Armor ❌terra Pro-4X [New Hotness]
Ripper's Avatar
Not going into 4lo is usually a bad 4lo switch/sensor that’s on the t case itself.
It’s most likely the transfer case control module. I bought a low mileage one at a auto recycler for about $75. Theybare very easy to change. One maybe two wire connectors (can’t remeber) a vacuum/breather line, and a couple of bolts. It will take you longer to jack it up and put stands under it than it will take to change it.
Ripper is offline
post #5 of 27 (permalink) Old 03-25-2019, 09:40 PM
He said the entire transfer case was changed too. If it weren’t for that, I would have suggested the same.
Very odd issue considering the info given.
post #6 of 27 (permalink) Old 03-26-2019, 01:00 AM
Ripper's Avatar
The down side of posting while at work. I’m usually only able to briefly skim the original post and then respond.
Ripper is offline
post #7 of 27 (permalink) Old 03-26-2019, 03:06 AM Thread Starter
2007 Pathfinder
All wires from transfer case CU to ECU, automatic gearbox CU are checked and like new - this what the mechanic said
No lights at all, at some point after 1h of blinking I'm getting 4x4 Light On (the orange one).
I've changed the entire transfer case, but I'm using my transfer motor and my control unit. At the end the mechanic said that mine transfer case was okay too. 1 year ago another mechanic told me that I should get another one (so I bought used one). About Control Unit we tested with second hand one and also with one from same car in the service center (but with manual gearbox).
kivanov is offline
post #8 of 27 (permalink) Old 03-26-2019, 06:24 AM
Sounds like the transfer case motor is bad. That will cause your exact symptoms. I’ve seen several of those go bad.
post #9 of 27 (permalink) Old 03-27-2019, 09:11 AM Thread Starter
2007 Pathfinder
I think that if I'm trying to switch to 4H/4L it works (I'm far away from home now). Is there any electronic circuits inside the motor or it is a simple motor? And what is the best way to test it? Can I just disconnect it from transfer case CU?
How many motors(actuators) transfer case has?
1. My original transfer case has attached - LM1004-03, so the other one in the car is using it's own LM1004-03. The one in the car uses my original 33274-7S110 (may be my numbers are a bit different)
2. I have in the basement my original transfer case with it's own LM1004-03 and 33274-7S110 detached from the second transfer case.
I think that 33274-7S110 - is related to changing the modes 2H/AUTO/4H/2L and LM1004-03 is somehow related to auto mode?
kivanov is offline
post #10 of 27 (permalink) Old 03-27-2019, 10:14 AM
I was getting U1000 and P1808 codes in the transfer control unit on the 06 pathfinder when I started helping out with it. Those problems went away when I replaced the old white IPDM with a newer black one. I think the IPDM was either directly flooding the canbus with garbage or not supplying enough power to other canbus devices which then flooded the comm wires with garbage. Either way the ABS, ECM, TCM and TCU couldn't talk to each other through all the noise and the other problems just evaporated when the noise was cleared up. If you have U1000 codes popping up in any controller you have basic canbus problems to deal with first.
Have you got a copy of the FSM? You'll want the TF section. Those diagnostic flowcharts are really good.
Do you have the ATX14B or the TX15B? The ATX14B has "AUTO" on the knob between "2WD" and "4H". The 2010 pathfinder I help with has the ATX14B and the 2006 pathfinder has the TX15B more like my 2009 xterra has. (No "AUTO" mode.)
All Rear Diff Gear Ratio by Years and Trim tfxluc Powertrain & Driveline 12 06-01-2017 07:09 PM
2006 Xterra Front Hubs Locked in 4x4 Gopats Powertrain & Driveline 14 02-26-2017 04:08 PM
4x4, ABS, Parking Brake, Slip, VDC Lights all 'ON' humz Brakes, Tires and Wheels 16 01-14-2014 08:40 PM
Stuck in 4LO and 4X4 Malfunction Light ON (2WD, 4X4, & 4LO Trk Axle Image Blank) bakersdozen Powertrain & Driveline 65 01-03-2013 08:45 AM
4x4 Maintenance and Usage U235 General Xterra 3 08-06-2010 09:10 PM
