Swapped another m205, Ratio not Matching - Page 2 - Second Generation Nissan Xterra Forums (2005+)
 6Likes
post #11 of 21 (permalink) Old 03-02-2019, 02:30 PM Thread Starter
2008 Sex-Terra USAF Vet, 04-08, F-16 Crew Chief
Sexy-Terra's Avatar
Does the same apply to the rear diff?
I swear, I mine as well just start bathing in gear oil.
Titan length rads 2.0, .5" top plate spacers, Titan swapped, 3.36 converted w/m226, locker bypass, Daker rear leafs w/HD add a leaf, 3-5" Bils, Adj shackles, IMS spacer, Magnaflow 2 in-1 out muffler with OEM y-pipe delete, KNN drop in, OEM fogs added, Ridged LEDs, Blacked out X
Sexy-Terra is offline
post #12 of 21 (permalink) Old 03-02-2019, 02:34 PM
yes it does.
ĒYou are free to choose, but you are not free from the consequence of your choice.Ē
jsexton is online now
post #13 of 21 (permalink) Old 03-02-2019, 03:49 PM
JNR
JNR's Avatar
Didn't the non-P4X manuals come with 3.54 ratio? As mentioned above, counting the teeth and doing the math is probably the best verification without diff tag (presuming correct one).
JNR is offline
post #14 of 21 (permalink) Old 03-02-2019, 04:07 PM
You don't even need to count. It is stamped on the ring gear. Absolutely no question what the ratio is if he looks.
Yes, the open m226 out of a manual non offroad/pro4x is 3.54.
post #15 of 21 (permalink) Old 03-02-2019, 06:43 PM Thread Starter
Sexy-Terra's Avatar
Iím gonna open all three diffs up when i have a day I donít need to drive anywhere. Beyond frustrated.
post #16 of 21 (permalink) Old 03-02-2019, 07:00 PM
NYTKSHR's Avatar
Did your rear diff come with the electric locker? If not you likely are at 3.54. Now if you find the front is a 3.36 there are likely many on here that have 3.36 rear ring and pinion that you can get cheap and put in or buy another rear with a locker and 3.36 gears and try to sell what you have. If it has a locker and 3.69, many people would like what you have and you can likely sell for what a 3.36 will cost you.
NYTKSHR is offline
post #17 of 21 (permalink) Old 03-02-2019, 08:59 PM Thread Starter
Sexy-Terra's Avatar
The main reason i got started down this path because swapping to a m226 with e lock was cheap and returned a lot.
So....just opened the rear and it is 3.357 - 47/14
But while inspecting I believe I found my 3 year long clunk!!! When I discovered it my eyes almost watered up. I have replaced everything and went above and beyond the average search for this damn clunk! 3 years of wondering, searching, listening to it. Finally got the basturd!!!! Now Iím gonna kill it! Bustiní our the 6.5 Grendel!
Iím not sure what the part is, itís for sure apart of the electronic locker. Iím gonna take a video and post it.
Happy as a pig in ****!
jsexton likes this.
post #18 of 21 (permalink) Old 03-02-2019, 09:03 PM Thread Starter
Sexy-Terra's Avatar
On the other hand, I am perplexed that I have purchased three separate M205 front differentials from three different junkyards from three different coasts across the United States. And every single one of those differentials were said to be 3.357 ratio but weíre not.
What is the luck in that? From three separate sources? I really find it hard to believe. Iím still opening my front differential I have to see the numbers stamped on that ring gear to be fully convinced. Seriously what are the odds?
post #19 of 21 (permalink) Old 03-02-2019, 10:29 PM Thread Starter
Sexy-Terra's Avatar
Video link :
https://m.youtube.com/watch?feature=...&v=rLuqUAmmpPI
post #20 of 21 (permalink) Old 03-02-2019, 11:09 PM
2006 Solar Yellow Xterra OR
Wilson06offroad's Avatar
Just watched your video, I'll attach a diagram at the bottom for your reference. The part that you described as clunking is the actual solenoid for the locker (#25) and the retaining plate (#14) holding it in place from rotation and snapping the wire. As far as that plate moving, that is very odd. Mine fit tightly... Don't get discouraged, I have almost completely rebuilt my m226 other than the pinion and bearings. Maybe try ordering that retaining plate and see if it tightens up?
Wilson06offroad is offline
Harrop/Eaton M205 Locker for 2ndGen Titan Swapped Xterra/Frontier/R51 Pathfinder sheller73 Powertrain & Driveline 7 09-05-2018 11:26 PM
The 5 Second Air Fuel Ratio Reset Procedure Shiny Powertrain & Driveline 21 06-20-2018 10:26 AM
SOLD: m205 Diff - 3.357 Gear Ratio 240addiction For Sale 7 03-01-2018 08:20 AM
FS: M205 and CV's 3.357 Ratio 240addiction For Sale 5 02-22-2018 08:18 PM
All Rear Diff Gear Ratio by Years and Trim tfxluc Powertrain & Driveline 12 06-01-2017 07:09 PM
