So I let Air into my Cooling System - Second Generation Nissan Xterra Forums (2005+)
post #1 of 12 (permalink) Old 03-01-2019, 03:51 PM Thread Starter
2015 Glacier White Xterra S 2wd
Just attempted doing my first coolant drain and fill. Watched a couple videos... one guy never opens the radiator and only works with the reservoir.. another has the radiator open.
Somehow I ended up filling at the radiator with the res also open.
Heater blowing ice cold now.
So far ive lifted up the front of the vehicle and attempted purging the air from the system.
Tried with both caps off, one or the other caps off and squeezing upper radiator hose. NO luck
LOL anyone got any tips??
Thanks
drudge2010 is offline
post #2 of 12 (permalink) Old 03-01-2019, 04:00 PM
DaveN's Avatar
Youre likely low. Top it off, run till hot, then burb it safely. Do that a few times and you should be good.
Sent from my XT1575 using Tapatalk
DaveN is offline
post #3 of 12 (permalink) Old 03-01-2019, 04:04 PM Thread Starter
Ive got radiator filled to the top. and res is at max line.
Should i run it til hot with caps on, Let cool a couple hours then top it off again?
thanks for your help
post #4 of 12 (permalink) Old 03-01-2019, 04:09 PM
2006 Xterra OR
curt86iroc's Avatar
just keep running it and adding coolant.
curt86iroc is offline
post #5 of 12 (permalink) Old 03-01-2019, 04:30 PM
DaveN's Avatar
Yes, caps on and run it till hot, but don't allow it to overheat obviously. Use a towel to protect yourself and you don't need to wait hours.
DaveN is offline
post #6 of 12 (permalink) Old 03-01-2019, 04:37 PM
Keep cap on rad. Fill into expansion tank when cold with engine running. Close tank cap. Run til hot with heater on. Let cool again. Repeat until full and heater blows hot. May take several fills.
Check level in expansion tank with cold engine running.
MartinX is offline
post #7 of 12 (permalink) Old 03-01-2019, 04:41 PM Thread Starter
Thank you Thank you.
Im now pointing in the right direction
DaveN likes this.
post #8 of 12 (permalink) Old 03-01-2019, 04:43 PM
FWIW when I replaced my radiator last time I just ran the heat on high, kept the tank cap on and filled from the radiator until it started to overflow. Let it cool off and then filled the tank to the very top and for the next week checked it and added more coolant as needed before driving.
post #9 of 12 (permalink) Old 03-01-2019, 05:56 PM
There's also this method if you wanted to do it in one shot.
How-to: Bleed Air from Coolant Line on 2009 -2011 Xterra's - PBR
Longboardr is online now
post #10 of 12 (permalink) Old 03-01-2019, 06:07 PM
2010 Xterra X 4x4 6MT
BillySpivitz's Avatar
This is the method I followed (same method that MartinX describes), may take a bit longer overall but pretty easy to do every morning before going to work.
How-to: Correct and More Problems if Heater Blows Cold at Idle or No Heat
Also provides a great explanation on why you think you are topped off by looking at the "max" line in the degas tank, but you really aren't.
BillySpivitz is offline
How-to: ABS/EBD Live On/Off Switch General_Tarfun How-to's 2 01-31-2019 11:21 AM
Extra Air Flow Under Hood charpe3 General Xterra 6 09-10-2017 12:23 PM
ATF Temperatures and Cooling System Performance, Part 2 jeff_redx Powertrain & Driveline 20 06-12-2012 09:50 AM
Cooling System Performance Characteristics? silverflash Powertrain & Driveline 11 01-15-2012 11:37 PM
On Board Air (OBA) Setup RGJones Xterra Projects 19 09-14-2010 02:51 PM
