Well this Sucks... - Second Generation Nissan Xterra Forums (2005+)
 8Likes
post #1 of 15 (permalink) Old 01-29-2019, 11:18 PM Thread Starter
2006 Granite Xterra OR 4x4
rm975's Avatar
Well this Sucks...
Having seen the teeny spot the front output on the transfer case was making on the ground, I neglected my rig for far too long (years). Too many other things going on in life. The transfer case starting thunking the other day, so I parked it. Performed the front drive output seal upgrade.........and then put almost a full fill of fluid in the TC. Too little too late. The rear output has a lot of play in it. I am suspecting the supporting bearing(s) went dry and it ate itself up.
[FACEPALM]
62k miles on a barely used rig that's been more a toy than anything and I need a TC.
FAWK!
Adam12SD likes this.
[W6ORV] 2M/70CM Icom Mobile Dual Band / CB / 60 Amp Aux Power Buss / Front Suspension - Fabtech 6" Lift w/ Radflo COS's & 650# Eibachs / Rear Suspension - SOA Conversion, Deaver AAL & PRG Lift Brackets, Fox 2.0 Res / Tom Woods Double Cardan 1310 Driveshaft / BTF Diff Cover / Anytime M226 Rear Locker Mod
rm975 is offline
post #2 of 15 (permalink) Old 01-29-2019, 11:19 PM
Adam12SD's Avatar
[FACEPALM]
FAWK!
Dang it... This really makes me want to change out ALL the fluids on my truck. Scary to think about...
Adam12SD is offline
post #3 of 15 (permalink) Old 01-29-2019, 11:25 PM Thread Starter
rm975's Avatar
It's ironic, I am up on maintenance on our Dodges we tow heavy with and our tractors. My one pleasure vehicle I ignored, all I had to do was check that level periodically and not assume that tiny spot meant tiny leak rate.
rm975 is offline
post #4 of 15 (permalink) Old 01-29-2019, 11:32 PM
Adam12SD's Avatar
Well my weekend begins tonight. Which means fluid level checks and PMs start tomorrow morning. Fun fun fun. No to find a How-to for TC maintenance. Lol.
Adam12SD is offline
post #5 of 15 (permalink) Old 01-29-2019, 11:42 PM
caain's Avatar
@mk3racer is selling a transfer case.
Not a bad idea, honestly. The diffs and TC are simple, and you could always just do a drain and fill on the transmission if the fluid looks good, or go with a PMF.
My X,
caain is offline
post #6 of 15 (permalink) Old 01-30-2019, 01:33 PM
ldstruckn's Avatar
Is the tc just a fill plug and drain plug set up?
ldstruckn is offline
post #7 of 15 (permalink) Old 01-30-2019, 01:37 PM
Yes, fill plug and drain plug.
Thankfully transfer cases are cheap and there are a lot of them out there.
funkierfawn21` likes this.
post #8 of 15 (permalink) Old 01-30-2019, 02:38 PM
2012 Lava Red ❌terra S
ZheKing's Avatar
yes remove fill plug first to make sure you can actually get it out / back in.
mtnbound and BlackbirdSR71 like this.
ZheKing is offline
post #9 of 15 (permalink) Old 01-30-2019, 04:05 PM
2012 Night Armor Xterra S
Mastermind46's Avatar
Just did all of the fluids end of December. Way easier than expected with a fluid pump. Unfortunately my front seal just went out so I am having to deal with that. Piece of mind is good to have.
Mastermind46 is offline
post #10 of 15 (permalink) Old 01-30-2019, 04:32 PM
Airmapper's Avatar
Ouch. Mine is leaking also and I've been dawdling putting the new seal on because I hate doing vehicle work in winter. Heck a new seal, flange, and nut are in a box on my tool chest.
Last few times I've checked, it's taken around a quart to refill and only holds a little over 2. Leaking more and faster than I figured. Hoped it was like the rear diff, drips all the time but you open the fill plug and it's still spilling out the top.
Maybe this weekend, thanks for the scare.
2011 Nissan Xterra PRO-4X - 6 MT
Check out my:
Airmapper is offline
