Engine Rebuild - Second Generation Nissan Xterra Forums (2005+)
 23Likes
post #1 of 60 (permalink) Old 12-21-2018, 12:29 AM Thread Starter
2007 Xterra
Red face Engine Rebuild
Hello. I have a 2007 Xterra 4.0. My chain tensioner broke causing the timing to skip which possibly led to bent valve(s). I replaced the tensioners and timing chain but the compression was way to low. I figured what the heck. Just tear it down and rebuild the heads, hone out the cylinders and replace the rings, rod bearings, main bearings and oil pump while I'm at it. Maybe even the Galley Gasket. So I can have a fresh engine that can last awhile longer. I'm on a limited budget so can anyone that can suggest the best affordable needed parts that can purchased will be much appreciated. Thanks
Adam12SD, Chunjee and danyelle like this.
Allbrant is offline
post #2 of 60 (permalink) Old 12-21-2018, 02:19 AM
2006 Xterra 4x4
prideandufc's Avatar
Damn buddy you're doing the most. My two cents. I would just look for a used engine. That parts list for what you're going to need is going to equal or exceed what you would pay for a used motor. I know it's probably not what you want to hear but save yourself the aggravation of more financial surprises lurking inside that bad motor. Good luck with whatever you do
Sent from my SM-N950U using Tapatalk
bluez likes this.
prideandufc is offline
post #3 of 60 (permalink) Old 12-21-2018, 12:00 PM
2006 Xterra 4x4
I second this ... just look for a good used engine and be done with it. You think you have everything covered when doing an engine rebuild but there is alllllways more once you get it opened up.
I put a 2011 motor in my 2006 , I bought it for $1200CDN and it only had 71,000km and even still had the factory blue Nissan coolant in the galleys.
bluez and prideandufc like this.
CurtisF is offline
post #4 of 60 (permalink) Old 12-21-2018, 05:18 PM Thread Starter
2007 Xterra
I priced all the parts and to do a head rebuild it's $300 for both. The Head Gasket Set, Head Bolts, bearings, rings and oil pump and etc. is around $350 thru Ebay and Amazon. So I figured anywhere from $700 to $800 for parts and I'll have a fresh engine that I can probably put another 100,000 on it. The used engines with low miles in So Cal can cost around $2500. I know it can be somewhat time consuming but wouldn't you guys agree it's worth it now knowing that everything is good from the start?
BrianK and danyelle like this.
Allbrant is offline
post #5 of 60 (permalink) Old 12-21-2018, 09:16 PM
If you have the know how and time to dedicate to it I'd say go with the rebuild. Although the X engine is a strong one and I wouldn't have any doubts about a used one either.
prideandufc likes this.
post #6 of 60 (permalink) Old 12-23-2018, 08:39 AM
So I think what people are saying is that once you get into the rebuild it will get way more involved / expensive than you think.
How did you determine it was a bad valve? Have you done a compression test? Is it low on all cylinders or just one? If so, have you tried to ID whether its rings or valves? Basically, you do a compression test on all cylinders. If its low on compression squirt a very small amount of oil in that cylinder and try again. If the compression improves slightly then its likely rings. If it stays about the same its likely a valve. Search the WWW or you tube for better tutorials on that - but thats the basics. Don't forget to hold the intake a WOT well your doing your test.
I think your best bet is to try to ID the problem. If its one bad valve or something you might get away with just fixing that one head?
post #7 of 60 (permalink) Old 12-24-2018, 01:19 AM Thread Starter
2007 Xterra
I did a compression test and got the following results:
Passenger/Driver
Cylinders: 1-120 2-150
3-120 4-150
5-90 6-150
Allbrant is offline
post #8 of 60 (permalink) Old 12-24-2018, 06:21 AM
Passenger/Driver
3-120 4-150
5-90 6-150
So squire a tiny bit of oil in 1, 3 and 5 and try it again to see if it improves. If it does its likely rings. If it does not its likely valves. Like I said, google around there are some better tutorials on youtube, etc.
All the bad ones are on on bank 1 which is interesting. Maybe your lucky and just need one head replaced.
post #9 of 60 (permalink) Old 12-24-2018, 02:32 PM
How many miles are on the motor?
mtnbound is offline
post #10 of 60 (permalink) Old 12-25-2018, 03:55 AM Thread Starter
2007 Xterra
142,000
Allbrant is offline
