Doug Thorley Long Tube Headers - Page 2 - Second Generation Nissan Xterra Forums (2005+)
post #11 of 20 (permalink) Old 08-01-2018, 01:03 PM
JNR
JNR's Avatar
No cats? You will get those codes, as the up and downstream O2's are reading the same value...ECU thinks the cat is not fuctioning (cleaning) properly, so yeah without them...
JNR is offline
post #12 of 20 (permalink) Old 08-01-2018, 01:12 PM Thread Starter
2008 Xterra OR 6MT
Gothere's Avatar
Shouldn't cause a misfire code though. Right?
Gothere is offline
post #13 of 20 (permalink) Old 08-01-2018, 01:36 PM
no, it will throw the p0420/p0430 catalyst efficiency below threshold codes.
Your x will only throw misfire codes if it is only misfiring. P0300 - P0306 as already mentioned.
here is the list of codes
https://www.thenewx.org/forum/11-pow...-ii-codes.html
pictures of your headers would be helpful to let you know if they are long tubes or not. If short tubes and you have 4 cats, and are throwing those codes, you need to replace the cats ASAP.
post #14 of 20 (permalink) Old 08-01-2018, 01:42 PM Thread Starter
2008 Xterra OR 6MT
Gothere's Avatar
I'll post a picture later.
I am very familiar with what cats looks like and I'm very positive I don't have any.
Gothere is offline
post #15 of 20 (permalink) Old 08-01-2018, 02:02 PM
JNR
JNR's Avatar
FWIW - I have LT headers (DT) and magnaflow high flow cats and do not get any codes. Only time I did is when one of the O2 sensors touched the heatshield and blew the fuse. However, NONE of those several codes were the 0420 (driver) or 430 (pass)...after I replaced the fuse and reset from reader, they went away. I know this isn't what you are getting, just mentioning that in the last 3 years or so, never had a cat code running this setup.
Gothere likes this.
JNR is offline
post #16 of 20 (permalink) Old 08-01-2018, 02:14 PM Thread Starter
2008 Xterra OR 6MT
Gothere's Avatar
I think I will get some performance cats at some point. Thanks for the info! Do your LT hang down just about even with the frame rails?
How many cats did you add? 1 or two?
Gothere is offline
post #17 of 20 (permalink) Old 08-01-2018, 03:15 PM
JNR
JNR's Avatar
They go about down to framerails, yeah. However, they really need to call them "medium (length) tubes" IMO, as the primaries really aren't that long...when I think of LT, it means say 32" to 36" long.
I'm only running 1 cat per side, 2 1/2" tube (pipe) dia each...
My headers are ceramic coated, but even so, try to install cats as close to header collector flange, as physically possible. Reason being is that the operational efficiency is based on exhaust heat...this will help you not get a code also.
Gothere likes this.
JNR is offline
post #18 of 20 (permalink) Old 08-01-2018, 03:23 PM Thread Starter
2008 Xterra OR 6MT
Gothere's Avatar
Which cats did you use?
Gothere is offline
post #19 of 20 (permalink) Old 05-03-2019, 12:37 PM Thread Starter
2008 Xterra OR 6MT
Gothere's Avatar
I'm bringing this thread back up, because starting a new one is unnecessary.
I found some Apex Precision MFG secondary cats, with an O2 hole for $145 on ebay. They seem like they would do the job, and my question is with only one cat per side, should I get a code? My hope is no, and it looks like I may be in the clear based on the comments above.
Also, what brand on your cats JNR?
https://www.ebay.com/itm/05-10-Xterr....c100667.m2042
Gothere is offline
post #20 of 20 (permalink) Old 05-03-2019, 01:15 PM
JNR
JNR's Avatar
I have magnaflow cats, 2 1/2" which I bought on sale at Pep Boys for like 80/ea IIRC.
Have not had any codes, although the only issue is one of the heatshields came loose and caused a rattle...it was more of the installer issue IMO but they are not attached real well to begin with IIRC (spot welded)...been awhile since I looked at them though...fixed it with a hose clamp for temp, works fine like that though to keep it quiet.
Gothere likes this.
JNR is offline
