SOLVED: Stuck in 4LO with 4WD Light - Second Generation Nissan Xterra Forums (2005+)
post #1 of 25 (permalink) Old 07-28-2017, 06:11 PM Thread Starter
2007 Frontier SE
I am actually in a 2007 Frontier (Manual) 4x4 and it is stuck in 4 LO. I have tried driving in reverse, forward, brakes and neutral. I have also bench tested all 4 relays and the 2 associated 10A fuses as good. Next I am going to remove the Actuator motor and check that it works with positive and negative voltage.
The 4WD Malfunction Codes is 11 (flashes):
11 ---> Actuator motor
- Motor does not operate properly due to open or short circuit in actuator motor.
- Malfunction is detected in the actuator motor. (When 4WD shift switch is operated and actuator motor is not operated).
- Malfunction is detected in transfer shift high relay or transfer shift low relay.
Two questions - 1. Any other advice or things to try?
2. Is there way that I could manually reconfigure the transfer case to 2WD (from 4-Lo to 4-Hi and then to 2WD) to make the truck drive-able?
Thanks,
maukiman
maukiman is offline
post #2 of 25 (permalink) Old 07-28-2017, 06:15 PM
Try searching for stuck 4lo site:thenewx.org in Google.
post #3 of 25 (permalink) Old 07-28-2017, 06:15 PM
2007 Silver Lightning Xterra Off Road 6MT
zach_attack's Avatar
It sounds like you are past this part, but just to make 1,000% clear, the truck MUST be in neutral and at a full stop to shift into or out of 4lo.
Are all of your ABS sensors fully functional?
: 392
Got extra time and money? Start Here:
zach_attack is offline
post #4 of 25 (permalink) Old 07-28-2017, 06:22 PM
Try giving the actuator motor a few light hammer taps when trying to shift. Much like a window motor the brushes can get on a dead spot and a little rattle can free them up.
post #5 of 25 (permalink) Old 07-28-2017, 07:37 PM Thread Starter
2007 Frontier SE
I have been reading the 4WD light threads and trying some of the suggestions. One I have not tried is removing the battery. I'll try that and giving the motor a knocking.
For some background - the battery died on me a few weeks ago. The battery was replaced, but then removed from the truck while I was working on the timing chain guides. The truck had not been in 4-Lo until I parked it in 4-Lo for the maintenance - I wont be doing that again....
Thanks
maukiman is offline
post #6 of 25 (permalink) Old 07-29-2017, 11:11 PM Thread Starter
2007 Frontier SE
Today, I unhooked the battery for 20+ minutes. I set the 4WD selector switch to 2-Lo, applied power and started the truck. The 4WD light came on within 2 seconds. Same story with the switch in 4-Hi.
So I removed the Actuator Motor and fed it + and - 12 VDC, it rotated in each direction.
Looking at a thread about converting a 2WD Xterra to 4x4 with some pictures https://www.thenewx.org/forum/15-how-...tml#post788492
The position of my transfer case shaft slot doesnt match up to any of the positions shown by USMMA11NC for 4hi, 2hi, nor 4lo. (post#3 in How-to: 2wd to 4x4 Conversion ) So I am unsure as to the exact gearing my truck is stuck in, but it feels like 4lo as I cannot get going very fast.
Here is the position of my shaft:
(see following post) almost like this ' \ ' but 45 degrees
So I am thinking that I need to manually move the transfer case to 4lo with the battery off and then reconnect it and start up the truck to see if that fixes the issue. To do this would I just rotate the shaft clockwise another 90 + 45 degrees?
Some noob questions, can the shaft only rotate a total of 90 + 180 degrees? Are there hard stopping points?
Thanks.
(I have too few posts to post urls)
maukiman is offline
post #7 of 25 (permalink) Old 07-30-2017, 12:03 AM Thread Starter
2007 Frontier SE
I can post links now.
The position of my transfer case:
maukiman is offline
post #8 of 25 (permalink) Old 07-30-2017, 11:52 AM Thread Starter
2007 Frontier SE
I think I found the answer in the FSM.
maukiman is offline
post #9 of 25 (permalink) Old 07-30-2017, 01:51 PM Thread Starter
2007 Frontier SE
I was only able to rotate the rod about 90 degrees counter-clockwise. If I rotated if there other direction there was a springiness to it and the rod rotated back to the original position - as if I was applying force against a tensioner. I'll match the actuator motor to the new position and see what happens.
maukiman is offline
post #10 of 25 (permalink) Old 07-30-2017, 05:26 PM Thread Starter
2007 Frontier SE
Ran thru the 4WD Diagnostics twice, was getting the 2.5 sec repeating long flash which indicates - 'Circuits that the self-diagnosis covers have no malfunction.'
The 4WD selector switch was in 2Hi. But the 4x4 Display diagram showed 4x4 and a flashing 4 lo.
So I drove it around a little, first fwd then reverse in straight lines then with some slight turning back and forth. Then I used the selector and switched it to 2Hi. There was some slight grinding from the actuator motor - and then the 4x4 diagram when blank and the 4WD idiot light came on.
I just removed the Actuator again and the transfer case rod is back to the '\' position. It will turn 90 degrees clockwise, but will spring back it turned counter-clockwise.
any ideas? Should I try jacking the whole truck up to see if I can get it out of 4x4?
Thanks
maukiman is offline
