Water Crossing Preparation Guidelines - Second Generation Nissan Xterra Forums (2005+)
 8Likes
  • 5 Post By ChrisHaynesUSA
  • 2 Post By maXTERRA
  • 1 Post By mulemarine
post #1 of 6 (permalink) Old 01-11-2016, 07:57 PM Thread Starter
ChrisHaynesUSA's Avatar
Copied from a link sent to my email, some good ideas
Water Crossings
The most fun thing you can do with your 4wd is a water crossing. It can also be the most challenging and expensive. Your 4wd is not an amphibious vehicle. Because they are not waterproof, the actual depth of water you can cross depends on the vehicle you are crossing in. Many soft roader vehicles cannot cross rivers and creeks at the same depth as a lifted Nissan Patrol for example.
It is important to be prepared before attempting a water crossing. Inexperience and lack of preparation can cause a vehicle to become stuck very quickly. Prior to crossing water, it is a good idea to prepare your recovery equipment. In the case of getting stuck, you don’t want to be searching for your snatch strap while the water comes rushing in!
Preparation for Crossing Water
A rule of thumb when attempting to cross a river or creek is “if you cannot walk it, you cannot cross it”. Make sure you always walk the crossing before you attempt to drive across.
A 4wd vehicle will tend to float until water actually seeps into it. If the water height is above your wheel height, it is nearly always going to be impossible to pass. An added bonus of walking the crossing is you allow your axles / diff and gearbox time to cool down before you enter the cool water.
Diff Breathers
If a hot axle touches cool water, it will cool very rapidly. The air pressure inside the axle will be lowered and the diff housing will draw air through its breather. Extending your diff breather higher up on the vehicle will allow your diff to breath air instead of sucking in water whilst performing a crossing.
Air Intake Snorkels
When an engine breathes in water, it will almost always end in tears. Bent rods / valves and crankshafts are often the result. This is often a very costly repair and one to be avioded. The location of your air intake is very crucial to how well a vehicle can handle fording a water crossing.
A common solution for this is to fit a snorkel. This relocates the air intake to near the hieight of your roof line. Snorkels also help when driving in dusty conditions allowing the engine to breathe cool clean air from up high.
Safari Snorkels
Pioneered in Australia in the early 1980's, Safari Snorkels were born out of a need to protect 4WD engines from the hazards of dust and water commonly encountered in touring and off road applications.
Protecting Your Engine
Using a “water crossing bra” across the front of the 4wd will create a bow wave at the front of the car as long as you maintain momentum. The result will be less water in the enginebay and the radiator fan will not spray it over the ignition leads and spark plugs. It is also less likely the fan will try to propel its way into your radiator.
A diesel vehicle is known to be better for water crossings as they have no ignition system. It is still advisable to proceed with caution in a diesel vehicle however.
If you do become stuck in the middle of a crossing, it is recommended to climb out of the window rather than open the door and flood your interior. It is a good idea to spray enginebay electrics and ignition with a water repelling agent such as WD40 before entering the water.
Radiator Fan
After you have sprayed your ignition and electrics, have a look at your radiator fan. Most 4wd’s have a viscous fan coupling driven by a belt from the engine crank. If you can turn the fan with the engine off, you have a viscous coupling. If you can’t turn the fan, you have a fixed coupling.
In case of the latter, you should disconnect your fan belt before attempting a water crossing. If you dont, and water enters the enginebay, your fan may act as a propeller and bend forward digging into your radiator. Not something you want to find once you have made it throguh the water crossing!
Walking A Water Crossing
It is always recommended to walk a water crossing before attempting to drive it. When walking through the river or creek crossing, make sure you walk where you intend to place your wheels so you can feel for hidden rocks or potholes. This will aide you in checking the depth of water in the crossing.
Potholes (caused by others attempting the crossing and getting stuck) are an indication of the difficulty of the crossing and should be avoided when attempting to cross. If you can, it is a good idea to place markers or stand in place of pot holes or large rocks in the crossing so as the driver can avoid them.
Water Crossing Driving Techniques
Visualise the path you wish to take through the water, remember where you walked and put the vehicle in low range. First or Second gear is good for creating just the right bow wave as well as allowing you the torque you need should the vehicle bog down.
Speed is a very important factor when crossing a water crossing. Make sure you do not go too fast as it will send water straight into the enginebay and may flood the engine. Avoid using the clutch if possible as this may allow water to come between the friction plate and the flywheel.
If you do start to feel a loss of traction, make sure you do not over-rev the engine. It is better to back off the accelerator and try to regain traction.
If the engine stalls, put the vehicle in neutral with a minimum of clutch usage and attempt to escape the water in first gear low range.
Maintaining Your Car After A Water Crossing
When you are at the other side of the water crossing, and you’re back at home. Be sure to check the diff oil for water. This is a relatively simple job since oil floats on top of water.
Simply release your diff oil drain bolt and allow a small amount of oil to drain into a container. You will be able to see the water in the oil as a milky white mixture. If you have water in your oil, make sure you drain the diff oil and replace it. It is also possible to flush the diff oil to remove all traces of water.
Gearboxes, transfer cases and engine oil can also become contaminated with water after a water crossing. This usually will only occur if you become stationary in deep water.
Check your other exterior mounted accessories such as winches, as these can sieze up unless maintained.
Water crossings should be taken with caution as they have the potential to do a lot of damage. With the right preparation and maintenance, you can complete many uneventful water crossings with ease!
Watercrossing Summary
Vehicle Preparation
Walk the crossing to check its depth.
Don't cross fast flowing water.
Place markers at hidden obstacles.
Place a tarp across the front of the vehicle.
Disconnect the fan belt if a viscous coupling fan is not fitted.
Spray water repellent on distributor and ignition wires.
Pack recovery gear on top, ready for use.
Driving Technique
Take off seat belt and wind down window.
Use low range 2nd gear (in most situations).
Drive at a steady speed to create a bow wave.
Avoid using the clutch.
Do not over-rev engine if you lose traction.
If engine stalls, place in neutral without using clutch to restart. Takeoff in 1st low.
Post Watercrossing maintenance
Check diffs etc for water if depth above axles.
Check winches if fitted
Read more: 4wd Accessories at Tough Toys | Buy 4x4 Accessories, Off Road Accessories, Touring & Camping Gear online! - Water Crossings
ChrisHaynesUSA is offline
post #2 of 6 (permalink) Old 01-11-2016, 08:15 PM
Veteran & LPM
VMBiohazard's Avatar
Always awesome info from Chris!
VMBiohazard is offline
post #3 of 6 (permalink) Old 01-11-2016, 10:02 PM
2006 Night Armor ❌terra S
maXTERRA's Avatar
Another major point to always consider...
KEEP MOVING! DO not park in the water submerged. Get in an get out as quickly as possible.
Parking or stopping allows water to seep into most every exposed bearing, bushing, u-joint, alternator etc. They may be sealed, but aren't waterproof for ever.
Wheel bearings, u-joints, bolted assemblies such as UCA's & LCA's will all suffer.
Then once you're home, grease everything greaseable to expel the water.
Whenever you replace or install bolts under the frame or on suspension components, Anti-seize is your best friend. Use it and you'll get stuff apart next time. Don't and you'll be cutting or breaking stuff apart.
Cam bolts, shock bolts, spring eye bolts, bumper bolts, u-bolts are a few I can personally vouch for...
lowhombre and VMBiohazard like this.
"I am concerned for the security of our great Nation; not so much because of any threat from without, but because of the insidious forces working from within."
Douglas MacArthur
maXTERRA is offline
post #4 of 6 (permalink) Old 01-12-2016, 02:14 PM
2005 Granite Xterra S
FaroutX's Avatar
Great info!!!!
My Xterra Page >
“Destiny is not a matter of chance, it is a matter of choice; it is not a thing to be waited for, it is a thing to be achieved"
FaroutX is offline
post #5 of 6 (permalink) Old 01-14-2016, 04:31 PM
Great write up!
General_Tarfun is online now
post #6 of 6 (permalink) Old 01-14-2016, 07:05 PM
2005 Night Armor Xterra Off Road 6MT
mulemarine's Avatar
Another word of advice, when crossing a stream a lot of people will want to tend to push the nose of the vehicle into the flow of water. The increased resistance can make travel difficult, if not impossible. Angling your truck with the flow of the water, even if it's just a slight angle, allows the momentum of the water to help propel your vehicle to the other next bank.
jdunker26 likes this.
mulemarine is offline
