Locking Differential ? - Second Generation Nissan Xterra Forums (2005+)
Go Back   Second Generation Nissan Xterra Forums (2005+) > Xterra Tech Topics > Powertrain & Driveline
Thread Tools Display Modes
  #1
Old 10-29-2006, 01:29 AM
SilverBullet SilverBullet is offline
Member
Send a message via MSN to SilverBullet
Default Locking Differential ?
I am hoping someone can help me out here.
I have never tried to engage the locking diff before last night. When I flipped the switch to lock the differential, the differential light just kept blinking. I have an auto. I was in 4lo and neutral. I read the manual and did what it said but no luck. I have only had my Xterra since June of 06 and it has seen only mild dirt road use, no trails or anything that would cause damage. The manual says you can engage the locking diff up to 4 mph. I looked in the engine and tranmission forum but didn't read anything that might explain what I am doing wrong.
Thanks
__________________
2006 OR Silver Auto
Fayetteville, AR
Mark
Old 10-29-2006, 07:07 AM
8th Man's Avatar
8th Man 8th Man is offline
Default
While in 4lo
Move shifter to neutral
Switch on the locker
The locker light will begin to blink
Now, move the shifter to the gear 1 position. Note - You know that you can lock the transmission into gear 1 by pushing the shifter to the right while in the lowest gear selection. I recommend you stay in gear 1 while locked.
Slowly move forward. The locker will sync. It helps to turn he wheel to the right or left as you're slowly moving forward to help it sync. up.
To disengage the locker, use the same technique. Sometimes turning off the locker is a bit of a fiddle job too.
  #3
Old 10-29-2006, 07:27 AM
kokopop kokopop is offline
Default
The light will blink until you move forward. Wow putting on the locker seems a lot simpler in a MT.
__________________
-Keith
05 Brawn Red OR 6MT, Shrock Sliders and front Bumper, Black Panther Skid Plates
  #4
Old 10-29-2006, 08:54 AM
RogueClimber's Avatar
RogueClimber RogueClimber is offline
2006 Xterra Off-Road
Default
Quote:
Yep! Sometimes an automatic ain't so automatic
__________________
Roberto Dowse
Red Brawn 06 OR 4X4 MT
Shrockworks Sliders & Front Bumper
Desert Red Interior...
  #5
Old 10-29-2006, 09:04 AM
8th Man's Avatar
Default
Yeah, you've got to plan ahead when engaging the locker with auto. If you're stuck, and you want to engage the locker, sometimes you can't move forward to get the thing to sync up. Kinda sucks but...
I've got the "system" down now. It's really no longer much of an issue.
  #6
Old 10-29-2006, 10:50 AM
Member
Default
Ok. Am I understanding that you need to be in 1st gear only and that it won't engage in "D"? I will give this a try this morning and let you know. Move forward and turn the wheels a bit. Sounds simple enough.
Thanks. I knew someone here would have the answer.
  #7
Old 10-29-2006, 11:47 AM
8th Man's Avatar
Default
The locker will engage if you simply leave the transmission in drive (D), however, you really don't want to the automatic transmission to change gears in the middle of a difficult obstacle while locked. That's why you should move the shifter to the gear 1 position and leave it there while you're locked. Make sure you move the shifter to the right thereby keeping you into gear 1.
  #8
Old 10-30-2006, 12:03 AM
Member
Default
I tried the same procedure that I tried the day before and it worked. The diff light came on right away this time and went off as soon as I turned it off. I tried it a second time but it took a few moments for the diff light to stay on. It would stay on for a second and then blink off for a second then on again. It did this 3 times and then it stayed on. When I turned it off, it took a few moments for it to turn off. I had to drive forward and turn the steering wheel a bit and then it disengaged.
I just need to get out on the trails more and get used to it. Almost seems as if maybe it too needs to be broken in to operate smoothly, but I could be way off on this point.
Thanks to all for the info.
  #9
Old 10-30-2006, 12:15 AM
usmc xterra's Avatar
usmc xterra usmc xterra is offline
Default
Electronical shifters act this way. I hate em! If you ever get to a rebuild shop, ask someone to show you one in action on the bench, you will see what I am talking about. An Air locker has the balls to move the gears a bit and line it all up and slide in. An electronic locker kinda puts the pressure on and allows it to move in when it gets a good chance, Thus the reason the steering wheel wiggle works so well. The MT goes in easy because in reality, the pressure is always changing on it where a Auto has steady pressure forward.
I know you think you understand what you thought I said but what you heard may not be what I meant! (Disclaimer)
Anyways. check one out in action if you ever get a chance. MC
__________________
http://i34.photobucket.com/albums/d1...a/Flagc301.gif
http://www.myspace.com/mcthexmodman
http://www.myspace.com/usmcmikes
Experience is a tough way to learn, because you get the test first...and the lesson afterwards. MC
  #10
Old 10-30-2006, 12:28 AM
Old Navy's Avatar
Old Navy Old Navy is offline
NewXcyclopedia Service / Mountain Regional Moderator / Administrator
2006 Xterra "S" 4x4
Default
Quote:
Tango Yankee, MC - You answered my next question.
__________________
"D'Garv"
Member #272
Stock Lightning Silver AT
Live Free. Drink Good Beer. Eat More Sushi.
You may not post new threads
You may not post replies
