How-to: "FRONT BRAKES" - NEW - Second Generation Nissan Xterra Forums (2005+)
Go Back   Second Generation Nissan Xterra Forums (2005+) > Xterra Tech Topics > How-to's
Thread Tools Display Modes
  #1
Old 04-23-2008, 02:05 AM
Bueller44's Avatar
Bueller44 Bueller44 is offline
Default How-to: "FRONT BRAKES" - NEW
Hi everyone,
Found out on the weekend that I only had 10% left on my front pads. Turns out, the inside pads were really worn. The outside pads still had lots of life left due to the fact that the pistons put pressure on the inside only.
It was going to be $110 for parts and another $180 for labour at the stealership so I decided to tackle it on my own.
I purchased some Raybestos front brake pads from Lordco. Got a good deal - $80 for the set. These are supposed to be great pads, they are ceramic and they are highly recommended.
Anyhow, I did the first side to learn how to do it and then I took pics of the second side.
Start by safely raising one corner of the truck using jack stands. Remove the tire.
This is what you will be looking at.
Basically you will only be touching 2 bolts. I am pointing each of them out with a screw driver below
Top bolt - this will only be loosened
Bottom Bolt - remove completely
You will need a 14mm socket or wrench to remove/loosen this. You may need also need another wrench for the nut on the oher side of the caliper. I didn't have the right size so I used a small crescent wrench.
Remove lower bolt
And loosen the top bolt.
This will allow you to rotate the the assembly up and over. This is way easier and safer than removing the top bolt and trying to suspend the assembly.
Now you can gain access to the old pads.
Remove the small wire that is inserted into each pad at the bottom.
The pads are easy to remove - the outside one get pulled firmly towards you
The inside one must be pulled in towards the truck - firmly
remove the upper and lower brackets (I believe these are rattle brackets to stop the pads from rattling)
Here are a couple of pictures comparing the old pads to the new.
Now it is time to put your new pads on.
My pads came with new clips, so I installed these first. They need to be firmly pressed on.
Then you put the new pads in the opposite direction that you removed them. Pretty easy.
Inside pad installed
Outside pad installed
Both pads installed and the new wire thingy inserted into the lower part of eah pad.
The next step is to compress the pistons for the pads. There are 2 for each side. I recommend that you compress one piston at a time. Essentially you are pushing brake fluid back and I think it is better to not force to much back at once.
I used one of the old brake pads and a C clamp. I turned it 1/2 turn at a time until the piston is flush with the rubber seal.
Then repeat for the other piston. This allows the assambly to fit over the new thicker pads.
Now, rotate the assembly back down over the new pads. Insert the bottom bolt back into the assembly first. Then tighten the top bolt again.
The assembly will jiggle a little bit, this is normal until the pistons are pushing up against the pad again.
Put your tire back on - lower the truck - repeat for the other side.
Next, you need to start your truck and pump the brakes 3 or 4 times to get the fluid pushing the pistons back against the pads. then go for a little test drive and see how nice these new brakes are - all for $80 + tax!!
Enjoy
__________________
Sorry guys, SOLD the X!!!! But I still lurk on the site!!
Old 04-23-2008, 06:48 AM
bluzfan bluzfan is offline
2006 Xterra S
Default
Nice! Easy to follow. I'll soon be doing this myself and couldn't have done it without this. Thanks for the great write up!
  #3
Old 04-23-2008, 07:18 AM
Mark's Avatar
Mark Mark is offline
Send a message via AIM to Mark
Default
ude, that is areally a great job on the write up. Im sure ill be needing to use this sooner than later. Thanks!
__________________
  #4
Old 04-23-2008, 12:03 PM
d-rap d-rap is offline
Default
Nice how-to Bueller. I'll be using it very soon.
__________________
My Xterra
David '05 OR MT
  #5
Old 04-23-2008, 12:18 PM
JIMBO's Avatar
JIMBO JIMBO is offline
2008 JEEP wrangler Unlimited Rubicon off-road
Send a message via MSN to JIMBO
Default
--Outstanding- good pictorial--
-- --JIMBO
__________________
-'08 JEEP RUBICON JK
--Man, you gotta have "style"
  #6
Old 04-23-2008, 02:21 PM
msobie64's Avatar
msobie64 msobie64 is offline
Member
2005 Xterra S
Default
Is it the same procedure for the rear brakes?
__________________
05 4WD S
  #7
Old 04-23-2008, 06:15 PM
miles miles is offline
Default
nice job...i guess the rotors didnt need changing?
__________________
My Xterra
http://www.thenewx.org/phpbb2/viewtopic.php?t=10253
________________________________________
All service and installation courtsey of Krown lakeshore
http://www.krown.com/lakeshore/
  #8
Old 04-23-2008, 10:07 PM
S_e_X-Terra's Avatar
S_e_X-Terra S_e_X-Terra is offline
2006 Xterra S
Default
Front and rear are basically the same. The rear is just a little smaller.
__________________
Call me Eddo
The first supercharged 2nd Gen. dont be jealous!!!
  #9
Old 04-24-2008, 12:21 AM
Bueller44's Avatar
Default
rotors were fine, I haven't felt any warping at all.
Brakes have worked great today!!
  #10
Old 04-24-2008, 12:25 AM
Default
Quote:
Must feel very satisfying.
You may not post new threads
You may not post replies
