Fuel Filter question - Second Generation Nissan Xterra Forums (2005+)
Go Back   Second Generation Nissan Xterra Forums (2005+) > Xterra Tech Topics > Powertrain & Driveline
Thread Tools Display Modes
  #1
Old 02-27-2008, 12:50 AM
Webfur's Avatar
Webfur Webfur is offline
2007 Xterra X
Send a message via AIM to Webfur
Default Fuel Filter question
How often should I change out the fuel filter?
I got those suggestion cards for 15k miles from the dealer. and everything I can do on my own or get it done free somewhere else, except for the fuel filter?
I cannot afford to do it myself, I already have 2 projects lined up, that need to be done at my friend's garage, and I just feel bad imposing, so this is going to be a dealer done thing.
and if i do need a new one, is there an aftermarket one?
__________________
Quote:
Originally Posted by Sidoba View Post
I just got a second job as a stripper... I found that I make more starting out naked and then people pay me to put my clothes back on! :-)
Old 02-27-2008, 02:45 AM
AZ-Ted's Avatar
AZ-Ted AZ-Ted is offline
2006 T-Swap Lightning Silver Xterra OR 4x4
Default
The fuel sending unit, pump, and filter is all one assembly. Change it out when the fuel sending unit fails...(mine failed at 30K, so I am good to go for awhile).
  #3
Old 02-27-2008, 11:25 PM
bmaloney's Avatar
bmaloney bmaloney is offline
2006 S 6 Speed
Send a message via AIM to bmaloney
Default
how hard was it to drop the tank? How much was the sender/assembly?
__________________
2006 Xterra, MT
My Xterra
  #4
Old 02-28-2008, 01:36 AM
AZ-Ted's Avatar
Default
Quote:
Mine was covered under warranty, so I have no idea about the repair or the price. There are a few people on this board that had to replace it out of warranty. A search for Fuel Sending Unit should find what you're looking for.
  #5
Old 02-28-2008, 08:58 AM
Jspecrx7 Jspecrx7 is offline
Member
Default
Are you talking about the fuel filter or the fuel pump pick up? FYI...The fuel pick up is mounted to the bottom of the fuel pump and looks like a sock. It keeps larger debre from entering the fuel pump and damaging it. The actual fuel filter is usually located further down stream after the fuel pump to filtrate smaller debre from entering the fuel injectors. I've got about 25k on the X and its time to replace it as soon as I find it. I would say changing out the fuel filter about every 20k is a good idea, its cheap insurance against dirty gas stations. The guys with all the bolt on performance parts, especially the few super charged would should really make this part of your routine maintenance. On my Rx7 which is pumping out over 500rwhp I change out the fuel filter about every 4K. I don't drive the Rx7 everyday so it works out to about once a year.
I've been around high performance vehicles from some time now and I can tell you I've seen first hand what a dirty fuel filter will do. BOOM..!! For instance on the dyno I've seen a car run a A/F ratio of 12.7 ish but with a fresh fuel filter the same car with same variables show a 12.0. In the tuning world thats a heck of a difference. I know you guys are saying that you don't drive a high performance vehicle or horse power monster. The VQ40DE motor is no joke, the motor is actually a stroked out VQ35DE, the same motor in the 350zs and Infiniti G35. I strongly recommend running 93 octane in your X or 89 at the very least. I assure you there will be a noticeable difference in performance just switching from 87 octane to 89 octane. Running 87 octane, some of you guys may be experiencing some engine knock. I know I did when first bought my X and used the recommended 87 octane. Here in San Antonio its only about a $5.00 difference between filling up with 87 and 93. Worth it to me. I recomend filling up at Chevron because they have an additive called Techron which keeps your fuel injectors clean. Maybe a I'll do a write up as soon as I find and replace the filter in the X.
  #6
Old 02-28-2008, 10:39 AM
Muzikman Muzikman is offline
2nd Godfather / Administrator
2005 Xterra Off-Road
Default
The fuel filter is in the tank and is part of the fuel pump/sending unit.
Running 89 in our X's is pretty much a waste. I have 50K miles on my X, I had played around with different oct gas and besides a lighter wallet it made no difference (in performance or MPG).
__________________
Muzikman
www.thexterra.org
  #7
Old 02-28-2008, 12:06 PM
Member
Default
^ strange, I figure you would benifit from the higher octane rating seeings how you are at a higher elevation. My fiance and I noticed a difference between regular 87 and 89 octane. The X runs smoother over all and doesn't get any sort of engine knock. I feel and hear the difference so I'm sticking with the 93 and 89 octane. As far as the fuel filter being intank that stinks. I would really like to change the fuel filter, but wouldn't want to buy the whole fuel pump setup to do so. Guess I'll throw a bottle of Techron concentrate in the gas tank.
  #8
Old 02-28-2008, 01:05 PM
Webfur's Avatar
2007 Xterra X
Default
For some reason, my truck hates chevron, I was get low MPG, it loves 76 or Shell, I can't figure out why.
  #9
Old 02-28-2008, 01:31 PM
Default
Is 76 still even around? I know all the ones in my area shut down and I know they are no longer the fuel of NASCAR.
I go where ever it's cheapest. If there was one in my area I would probably use a KwikFill as they are all American, from the oil to the refined gas.
  #10
Old 02-28-2008, 01:56 PM
JIMBO's Avatar
JIMBO JIMBO is offline
2008 JEEP wrangler Unlimited Rubicon off-road
Send a message via MSN to JIMBO
Default
Union 76 is as big as ever, it just ain't Independant any more--
--I've used Union 76 for 47 years, never used , other gas, except once outta Eagle Lake, I had to get 5 galons of Chevron, for trail saving reasons--
--The Union 76 brand is now known as:
--PHILLIPS 66 CONOCO 76
----P.O. Box 689140
--Des Moines, IA 50368-9140
-- --JIMBO
__________________
-'08 JEEP RUBICON JK
--Man, you gotta have "style"
You may not post new threads
You may not post replies
