DIFF LOCK Light Flickering / Constant 'ON' - Second Generation Nissan Xterra Forums (2005+)
Go Back   Second Generation Nissan Xterra Forums (2005+) > Xterra Tech Topics > Powertrain & Driveline
Thread Tools Display Modes
  #1
Old 07-01-2013, 12:35 AM
Neo1130's Avatar
Neo1130 Neo1130 is offline
2005 Xterra Off-Road
Default DIFF LOCK Light Flickering / Constant 'ON'
Took a trip today and my DIFF LOCK light was on. Thought maybe someone hit the button but it was off. Pulled over and tried to reset... Didn't work. Then I noticed it starting to flicker and go dim and bright. Did this to me about 3 times in all in my 300 mile trip today. I do have the diff lock bypass mod and that's all... Anyone else have this? Going to check the connections tomorrow...
Old 07-01-2013, 07:03 AM
josephhauler's Avatar
josephhauler josephhauler is offline
2009 Xterra
Default
the diff lock light is simply the end (ground) wire from your locker. It most likely has a loose or bad connection to the chassie.
  #3
Old 07-01-2013, 09:45 AM
Neo1130's Avatar
Default
Quote:
Looking at the wire diagram though, the electrical path for the light goes FUSE BLOCK ---> INST CLUSTER ---> DIFF LOCK LIGHT ---> DLCU.
There has to be a problem with either the DLCU or it HAS a connection to ground when it shouldn't. No wires are chaffed or damaged...
Could be the diff lock position switch going bad as well...
  #4
Old 07-01-2013, 11:23 AM
NixX's Avatar
NixX NixX is offline
2007 Super Black Xterra Off-Road 6MT
Default
http://www.thenewx.org/forum/showthread.php?t=55916
__________________
My Ride
  #5
Old 07-01-2013, 11:36 AM
Neo1130's Avatar
Default
Nixx... Those were the exact problems I have been having... Except the DIFF and VDC/ABS lights seemed to happen weeks apart and never on the same trip... Did you ever find a NEW switch? Ever get your stuff back together and up and running?
  #6
Old 07-01-2013, 01:54 PM
NixX's Avatar
Default
I never needed a new switch. After I removed the switch, cleaned it and drained and cleaned the diff everything was working fine.
Wierd that the DIFF LOCK and the VDC/ABS/SLIP lights weren't coming on at the same time. That might mean that you have something different going on.
REMINDER: (in case you didn't read the other thread in deatails) Do not remove the Diff Lock Position Switch (DLPS) unless you absolutly have to its a bitch to get back in.
  #7
Old 07-06-2013, 04:29 AM
2009 Xterra
Default
ahh you are right, I wired this switch/light up before and I thought the diff light was the last thing in the locker soleoid loop so that if for some reason the locker didnt fire, the circuit up to the light wouldn't close and illuminate the indicator light. I can tell you however that all of those lights are found on the main gage cluster pin harness behind the gauges. They could be corroded or dirty since all they need to turn on is a connection to your chassies. (ground)
  #8
Old 07-08-2013, 06:31 AM
jarmentrout jarmentrout is offline
2012 Xterra Pro-4X
Default
Drain and refill with correct oil and see if it works. cheap check for contaminated oil.
__________________
2006 OR MT (sold)
2012 OR MT
  #9
Old 07-08-2013, 08:48 AM
Surf and Snow's Avatar
Surf and Snow Surf and Snow is offline
Go Pack Go!!!
2005 Night Armor Xterra Off-Road - Expedition Style
Default
Quote:
The diff fluid would not be able to cause this. A chaffed wire near the rear diff would be most likely.
  #10
Old 07-08-2013, 01:47 PM
NixX's Avatar
Default
Contaminates, particularly metal particles, in the oil could cause a short/malfunction in the DLPS inside the diff. A drain might help. I'd also check out the connector.
I completely pulled mine apart and found nothing obviously wrong. I cleaned the switch and the connector, put it back together and the problems were gone.
You may not post new threads
You may not post replies
