m226 Chromoly Axle Shafts - Page 2 - Second Generation Nissan Xterra Forums (2005+)
Go Back   Second Generation Nissan Xterra Forums (2005+) > Xterra Tech Topics > Powertrain & Driveline
Thread Tools Display Modes
  #11
Old 12-28-2012, 08:21 AM
penski61's Avatar
penski61 penski61 is offline
Default
same here but i think they would need them because its not a common off the shelf blank
honestly they may only need one just to gets all the specs off of then who ever is interested in buying them just has to give the lengths they need
__________________
www.ruggedrocksoffroad.com
07 se cc 4x4
02 sc cc 4x4 (sas'd)
Old 12-28-2012, 09:56 AM
westracing01's Avatar
westracing01 westracing01 is offline
2009 Titan Swapped Frontier PRO-4X
Send a message via AIM to westracing01
Default
Definitely interested in this. Have no contacts with anyone but I've pissed away enough money on the truck to throw down some more.
The carrier design changed post '07 to go to the 4 spider gears, but did the axle shafts change? All the Frontier/Xterra M226's are 32 spline, so I would imagine that as long as you have an M226 with the E-locker, that the shafts would all be the same.
__________________
2009 Titan Swapped PRO-4X KC 4x4 6spd...
See my Build Thread for mod list and pics...
  #13
Old 12-28-2012, 10:38 AM
early 2010 early 2010 is offline
2010 OR
Default
Somewhere I found the spline count went up on the newer ones. Something about the same locker as the Titan and they went from 32 to 35 spline. Of course I can't find the source of that spec of info now that I am looking for it.
__________________
Was I the only one who was sobor and paying attention in college?
  #14
Old 12-28-2012, 10:52 AM
jeff_redx's Avatar
jeff_redx jeff_redx is offline
2009 Xterra Off Road
Default
The TSB on axle service, NTB10-008_REAR AXLE SEAL LEAKS, lists one interchangeable axle for both sides for non-locking M226, and a left and right for locking M226 rear assemblies. All years are the same for the axles.
It'd be safest to send the axles in, the manufacturer can measure all necessary dimensions.
Jeff
__________________
Life is not measured by the number breaths we take but by the moments that take our breath away.
  #15
Old 12-28-2012, 02:48 PM
penski61's Avatar
Default
another company for you guys to look into
http://www.branikmotorsports.com/axle.htm
  #16
Old 12-28-2012, 03:03 PM
Default
Yukon might be the way to go. They have a limited liftetime no questions asked warranty on the cromo axle shafts they currently make.
OK, so what does one need to do here? Call up one of these companies and see if they'd be interested in making us some chromoly axles? If they are, we get some money together, send the bread to Penski and he ships them to said company for R&D and hopefully production?
32 spline chromoly axle shafts with an ARB locker (or a grizzly locker) would make these axles pretty damn stout I should think.
  #17
Old 12-28-2012, 03:15 PM
penski61's Avatar
Default
you will have more of a chance getting these made thru a custom shop , trying to go thru yukon would be a mess i think because they would want minimum orders and deposits
also there may a chance if the titan now has a 35 spline arb to upgrade to chromoly axles in 35 spline and get the titan arb in 35 spline then you would have a pretty stong axle
  #18
Old 12-28-2012, 06:08 PM
jeff_redx's Avatar
Default
Quite a few years ago Mark Williams made custom axles, duplicates of an Olds axle. I sent the old axle to them and they made two at their advertised price for custom axles. I don't think there was a charge for meassuring the old axle, but I don't remember for sure. They didn't care if it for for 1 or 10, the price was the same. Their policy may be different now.
If somebody wants a set made, make some phone calls to companies that advertise custom axles.
Jeff
  #19
Old 12-28-2012, 08:41 PM
BoonDox's Avatar
BoonDox BoonDox is offline
2007 Avalanche White Xterra S - Titan Swapped
Send a message via MSN to BoonDox
Default
Didn't someone on this site go through superior and have custom axle shafts made with a titan bolt pattern. It could have been a Ford 9 was install and had shafts made with a 6 on 5.5 by pattern. Can't remember for sure.
  #20
Old 12-28-2012, 09:28 PM
BRUTAL's Avatar
BRUTAL BRUTAL is offline
2005 Frontier NISMO 4X4
Default
a note Ive done for years on axles is to run a paint pencil down the length(clean well first) this lets you visually see if the axle ever twists. Many times Ive seen twisted axles this way on drags cars. We may not run slicks and have wheels up launches, but we can shock them hard enough to twist and snap em. Also lets you know you have an issue when you may not know it
__________________
4.56 gears,OMF street-locked Nismo wheels Shrock skids, PRG arms. BFG KM2 305/70/16, owner built engine, N fabbed Ken Bell Super Charger setup 337 RWHP, UPREV
http://www.youtube.com/watch?v=Sn1EvGKO1Yo
You may not post new threads
You may not post replies
