Pretty simple but thought I'd put it up anyway.
1. Remove right rear tail light assembly (2 bolts, then pry gently as there are two plastic clips)
2. Run rubber/vinyl tubing behind bumper along frame rail and over exhaust heat shield. Ziptie as necessary. Ensure you leave enough slack to accomodate the suspension travel.
Webshots - Full Moon Over Gunsight Peak, Washington
3. Insert 1" aquarium airstone into end of tube http://www.petco.com/Shop/Product.a...t&Nav=215&N=24 4937&sku=257931&familyID=6367& (to keep dust out) available from any pet store.
4. Secure to tail light assembly using existing clips.
5. Remove breather from axel housing.
6. Pry cap from breather or purchase new nipple-type fitting. I didnt want to drive back to AutoZone so I just made the existing fitting work.
7. Fit tubing over breather, secure with small hose clamp.
:cheers:
Thats it, go drive through a big puddle somewhere.....of course theres always the issue of the front diff, tranny and t-case breathers but I didn't get a chance to look at all that yet.
:cheers:
