catalytic converter replacement questions - Second Generation Nissan Xterra Forums (2005+)
Go Back   Second Generation Nissan Xterra Forums (2005+) > Xterra Tech Topics > Powertrain & Driveline
Thread Tools Display Modes
  #1
Old 04-18-2012, 11:04 PM
bama16 bama16 is offline
Member
2006 Xterra OFF-ROAD
Default catalytic converter replacement questions
i got an CEL...had the wife take it in since i was at work and we had extended warranty. i don't know the codes that were thrown but they put down in the notes a 87716 diagnosis and that bank 2 cat needs to be replaced. i'm at 87000 miles so no go on nissan replcaing. this was to the tune of $1100 for one...i told them i'd do it myself. they said they measured air intake and output and found the driver cat to be the problem. i just ordered a magnflow cat for 260 shipped...i could have gotten a nissan cat through courtesy for like $500....figured magnaflow was just as good. does anyone know of that 87716 makes sense. they cleared the codes and it hasn't come back...but gas mileage is horrible at like ~10mpg. I plan on replacing the cat on friday...just wanna make sure i'm not missing anything.
thanks guys
Bobby
Old 04-18-2012, 11:45 PM
AZ-Ted's Avatar
AZ-Ted AZ-Ted is offline
2006 Xterra OR 4x4
Default
Next time the CEL comes on, get the codes read for free by AutoZone (or buy a code reader). P0430 is for an inefficient cat (bank 2), and P0420 is (bank 1).
I'm guessing that '87716' is probably that repair shop's internal billing designation for that job.
__________________
AZ-Ted's 2006 XOR 4x4
  #3
Old 04-19-2012, 02:13 AM
Member
Default
I don't know if it will...sadly we've been really busy and its been a couple months and it hasn't come back. But gas mileage is horrible...she took it to autozone and it was something like faulty fuel system or somethimg...covered a lot of possible issues from injectors to the cat...I will remove it and seenwhats goin on...thank you
  #4
Old 04-26-2012, 08:41 PM
HashX HashX is offline
2006 Xterra Off-road
Default
Do you know which bank is left and which one is right? I am getting a 430 and need to know which one to replace.
  #5
Old 04-26-2012, 08:42 PM
masscomguru masscomguru is offline
2006 Xterra S
Default
430 I believe is drivers side.
__________________
2006 Xterra S
Avalanche
  #6
Old 04-29-2012, 01:33 PM
2006 Xterra S
Default
Wrong thread.... Sorry.
  #7
Old 05-22-2012, 10:01 PM
Mobius128 Mobius128 is offline
Noobie
2005 Xterra SE
Default
I have the 430 on mine. At first I thought it was the downstream cat, when I finally replaced it with the O2 sensor, I spent around $300 for parts and labor(Napa, Autozone, and a tire shop) it still did not fix the problem. When I took it to an actual muffler shop they told me that it was really the Upstream cat and quoted me for $300 flat. Because of its location Id rather have them do it, so to me it sounds fair, but for you to be charged $1100, that sounds horrible! Meineke tried to charge me $2200 for one side, they said they would of done the other for twice as much.
You may not post new threads
You may not post replies
