08-08-2008, 01:17 PM
2007 Xterra OR
4wheelparts.com is currently having a sale on ProComp wheels. Buy 3 get 1 free. Here is the link to the the 7089s
http://www.4wheelparts.com/Wheels/Se...0073&t_pl=3635
08-08-2008, 04:33 PM
Supporting Member
2007 Xterra S 2WD
Quote:
Originally Posted by cjm_specv
I saw that and it made me want to get them.
but
All the 7089s I've seen installed have a -12mm offset and on the 4wheelparts website it shows on the 16x8 an offset of 0mm. Would 0 offset work on the x?
here's the link http://www.4wheelparts.com/Wheels/Xt...n=PXA7089-6868
And finally isn't the X bolt pattern 6on4.5?
__________________
Titan Swapped - Radflos - PRG shackles - Volant CAI - Cherry Bomb exhaust - KMA front bumper - 33" BFG KM2s
My Xterra
08-08-2008, 04:56 PM
-Gimp Moderator-
2005 Xterra S
No, the bolt pattern for us is 6 X 5.5. I have the lug-centric 7089's and have had them on since Nov '07, wheeled w/ them many-a-time and have had no issues. You just have to ensure that they are mounted, balanced, and torqued correctly and you're fine. I had a set of custom hub rings made up ($75) and they've been sitting in my garage since the beginning of the year. I talked w/ Greg @ PRG about this extensively and he ensured me the same thing (mounting, balancing, torquing) and said not to worry. That being said, would I have liked to waited until these hub-centric models came out? Sure, who wouldn't want a little security? Am I worried about mine and racing to order these? Not so much. Oh, and the 0mm offset is just fine, though that along w/ being a 16 X 8 will require a little more work on "melt mod" than just melting back the wheel well liner (I Dremeled a little bit of the metal off as well).
Reason: Had a couple grammar/spelling errors that were buggin' me!
08-08-2008, 11:47 PM
2005 Xterra Off Road
correction
Quote:
Sorry TXterra37, incorrect statement, we are 6 x 4.5.
Take the tape measurer and check dimension from center of lug to center of the lug directly across from it ... 4.5" ... its the first gen that is 6 x 5.5.
Our back spacing requirement is 4" to 5"
The 7089-6868 is the correct application for this wheel. I run the 6089-6868, exact same wheel in chrome (and have the spare sitting in my living room today). Go to http://www.procomptires.com/pxa7089.html click on sizes/specs.
7089-6868
16x8
6x4.5
-12mm
4" BS
2200lbs
26lbs
__________________
LA RANA
Tread Lightly, United Four Wheel Drive Association, Virginia Four Wheel Drive Association, TheNewX, NOAS, NORA, NOR, VA4X4, VAXC, GPAX, CX, CF, TT, Big Dogs Offroad
Reason: just for fun
10-20-2007, 04:54 PM
-Gimp Moderator-
2005 Xterra S
You sure those run only $112? 4WheelParts (website and local store) quotes around $140, cheapest I found was at offroadtoystore.com for $125!
10-20-2007, 10:40 PM
Quote:
Originally Posted by XterraVT
Miles listed it above my post w/ pics
here it is again
here are the specs pff the procomp site
part #7089-6868
Bolt Circle: 6x4.5
offset :-12mm
Backspacing: 4"
load lbs 2200lbs
weight lbs 26lbs
10-20-2007, 10:41 PM
I am paying $129 CDN.
10-20-2007, 10:51 PM
-Gimp Moderator-
2005 Xterra S
Aaaah, gotcha.
10-21-2007, 04:30 PM
-Gimp Moderator-
2005 Xterra S
Well now I'm torn between which wheels to put on my new BFG AT 285/75/16s:
http://www.procomptires.com/pxa8089.html - 'cuz I like the beadlock styling, but only found pics of them on an FJ, $118.34/per
or these, like XterraVT has
http://www.procomptires.com/pxa7089.html - 'cuz well, I've seen what they look like on an X, $125.56/per
HELP!!!
10-21-2007, 05:15 PM
I like the all black....my opinion is 7089
| Thread Tools |
| Display Modes |
Hybrid Mode
You may not post new threads
You may not post replies
Powered by vBulletin® Version 3.7.3 Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright ©2006 - 2010, www.thenewx.org The Nissan names, logos and slogans are registered trademarks of Nissan Motor Co. Ltd and is no way affiliated with this site. All posts are the property of the posters and are not the responsibility of thenewx.org, it's affiliates, web hosts or associated companies.
