How much should a tire rotation/balancing cost? - Second Generation Nissan Xterra Forums (2005+)
Go Back   Second Generation Nissan Xterra Forums (2005+) > Xterra Tech Topics > Brakes, Tires and Wheels
Thread Tools Display Modes
  #1
Old 07-23-2007, 02:55 PM
thespeakerbox thespeakerbox is offline
Member
Default How much should a tire rotation/balancing cost?
I just hit the 6k mark, and im due for tire rotation and balancing. How much should I be looking to spend?
Also - what is balancing? I understand the rotation , but is it really necessary to balance the tires?
__________________
2005 O.R. X
Old 07-23-2007, 03:07 PM
Grouch Grouch is offline
2006 Xterra S
Send a message via Yahoo to Grouch
Default
Rotation is good, I wouldn't worry about rebalancing unless there's a problem.
Balancing...think of a ceiling fan. If it's not balanced is sways, wobbles and if bad enough will make clanking noises. Wheel's are the same. If the rotational mass is not equally distributed there will be a vibration at speed. You will feel it in the steering wheel and if bad enough throughout the vehicle. It will accelerate tire wear and could be hard on other components.
So unless you are having vibrations, I wouldn't worry about balancing. I think most places charge about $10-15 for rotating the wheels. Once you buy new ones, dependent on where you bought them and had them installed that store may rotate them for free (I know NTB does).
  #3
Old 07-23-2007, 03:36 PM
Muzikman Muzikman is offline
2nd Godfather / Administrator
2005 Xterra Off-Road
Default
You do not need to balance the tires every time you rotate them.
Since tires are a molded they are not pefect. Balancing is when they take the tire and wheel, put it on a machine and spin it, the machine can detect where in the tire a wobble is. Then then put weights on to counter the wobble.
^^^He beat me too it.
__________________
Muzikman
www.thexterra.org
  #4
Old 07-23-2007, 03:39 PM
XKNUT's Avatar
XKNUT XKNUT is offline
Default
If you buy your tires from BIG-O they will include a free rotation every time you get your oil changed.
I'm not saying their oil changes are necessarily cheap, but my wifes a coupon clipper and I buy my tires from them so why not?.
Agreed. Unless you're missing a weight from one of your tires and/or experiencing wobble/vibration I wouldn't be concerned about balancing either.
__________________
2005 Grey OR MT
Radflo Coilovers, 750# Eibach Springs. Deaver AAl w/Bilstein 5125s.
FUGreenpeace
Keep the Internet Open
  #5
Old 07-23-2007, 07:22 PM
xterrock xterrock is offline
Default
$1.50 per tire at Walmart. Or if you say that you bought your tires from Walmart, rotations are free.
  #6
Old 08-16-2007, 06:26 AM
usmc xterra's Avatar
usmc xterra usmc xterra is offline
Default
Well I recently did a long run with a set of 285's BFG AT's Same day same time same trip same speeds almost identically equipped vehicles and the dude with the 265's (Same tire) got about 100 miles per tank than me.
SO, I said all that to say this,
I put my factory tires back on and realized the gain of 100 more miles per tank. But a had a serious balancing problem, Air soft pellets, Equal, two balances with weights and no cure.
SO, I go to my friends Stereo shop who also does wheels and he realizes that the machine (A pretty high tech one as he does the big wheel thing) does not have a center cone that fits our Xterra Wheels. So he had a special set of tools that used this kind of hub that coned down on the lug holes and he balanced it that way. That worked! His machine lets you balance it several ways, The weight on the outer part of the inside rim and a stick on inside the rim worked best.
It was like a 2 week dilemma for me, my average travel speed is in the 70's and out of balance is a real bad thing. Equal was not too much of a help. I added 3, 4, then 6 oz's and it ran the same each time, unbalanced after 62 MPH.
Great to be getting 300+ Miles per tank again!
MC
__________________
http://i34.photobucket.com/albums/d1...a/Flagc301.gif
http://www.myspace.com/mcthexmodman
http://www.myspace.com/usmcmikes
Experience is a tough way to learn, because you get the test first...and the lesson afterwards. MC
  #7
Old 08-16-2007, 11:28 AM
silverflash's Avatar
silverflash silverflash is offline
Default
I paid 65.00 or thereabouts for a lifetime balance and rotation from discoutn tire.. i get mine rotated and balanced every 7500 or so.. every other oil change...
__________________
2007 S 4x4 silver lightning- "BaseCamp" Edition
OEM fog lights,Nissan Bug Deflector,Nissan Seat covers,Trident white a/c unit mod
Rear Timbrens,Flexible mudflaps, GY DuraTrac 265/75R16 C-rated,bil 5100 shocks front/rear
K&N 57-6014 FIPK,Flowmaster 40/custom y-pipe, vistapro radiator, bully dog GT
  #8
Old 08-16-2007, 11:49 AM
robnfl robnfl is offline
Send a message via AIM to robnfl
Default
I put my factory tires back on and realized the gain of 100 more miles per tank...
MC, your killing me! I so badly wanted to put some 285/75's on my X so I was trying to justify the purchase. Well, with the way gas prices are I really don't want to destroy my fuel economy just cuz I want bigger tires. Well, at least you helped me decide what size...I'm sticking with the 265/75's.
Rob
__________________
'07 Night Armor OR 6MT
Shrock Sliders, Cobra 75wx CB, Keyless door pad, Yakima ski rack, Nissan Nav unit, K&N filter.
http://i176.photobucket.com/albums/w.../hypeobama.gif
  #9
Old 09-03-2007, 04:53 PM
willgr1's Avatar
willgr1 willgr1 is offline
2006 Xterra S
Send a message via AIM to willgr1
Default
pulling up an old thread, but just thought i would share
NTB rotates, no charge...they didn't even ask if i got tire there (which i didn't...but they did install them)
__________________
2006 Avalanche S AT
  #10
Old 09-04-2007, 01:09 AM
mike100's Avatar
mike100 mike100 is offline
Default
You do realize that going from 265's to 285's lowers the tires rpm at 60 mph. Or think of it this way, the larger donut rotates fewer times per mile and lowers your indicated speed on your speedo.
I'd take the 200 and whatever miles you got with the 285's and multiply that by about 3% to get close to actual mileage. anyhow, you definitely lose mpg with larger tires 9 times out of 10.
I have a set of pretty decent used bfg 285's stacked in the garage but am thinking of trading straight across for some highway 265's since I know I don't want to spend in gas, nor do I want to play with my aero losses with a lift.
__________________
2005 OR 6-speed
You may not post new threads
You may not post replies
