Flags! - Second Generation Nissan Xterra Forums (2005+)
Go Back   Second Generation Nissan Xterra Forums (2005+) > Xterra Tech Topics > Exterior
Thread Tools Display Modes
  #1
Old 05-28-2011, 11:00 AM
sylvesterthex sylvesterthex is offline
2010 Xterra X
Default Flags!
So I did a search and couldn't really find what I was looking for...
How do y'all mount flags on your X's?
I'm interested to see how!
My best guess is using a fire stick, but seeing as I don't have one (yet), just seeing what some other ways are!
Post up your offroad flags here!
Old 05-28-2011, 11:08 AM
piratex's Avatar
piratex piratex is offline
2007 F*** Jeep Cruiser yota fj
Default
ok so what i used was regular 3/4 pvc and regular 3/4 pvc mounts then i used a old liscense plate on the back side along with a 2x4 piece for added stability, if you dont use a back plate of something sturdy the pvc mounts willl come out while driving. with my mount i have driven up to speeds of 100+ and still have yet to lose it anywhere. i even tried using a special mount from the hardware store but it couldnt even take speeds over 30 and it broke. pm me if you have any questions or want more pictures.
__________________
The Kracken, the True 2wd
Now fj swapped
  #3
Old 05-30-2011, 10:16 AM
fangars's Avatar
fangars fangars is offline
Supporting Vendor: Xoskel
2005 Xterra S
Send a message via AIM to fangars Send a message via Yahoo to fangars
Default
__________________
Xoskel Light Bars, Light Cages and Offroad Accessories
http://www.xoskel.com/
Facebook
Upillar
  #4
Old 06-01-2011, 12:02 AM
2010 Xterra X
Default
fangars,
how'd ya put the flag up there? what'd you attach it with?
set up looks sweet!
  #5
Old 06-01-2011, 12:15 AM
Xterra1102's Avatar
Xterra1102 Xterra1102 is offline
2007 Altima SL
Default
I cut my flag stick to only about 12-14" long and just zip-tied it to my Firestik CB antenna. Worked like a champ.
  #6
Old 06-01-2011, 12:16 AM
fangars's Avatar
2005 Xterra S
Default
Quote:
Originally Posted by sylvesterthex View Post
fangars,
set up looks sweet!
Firestik antenna, antenna mount welded directly to roof rack. Not the best place for an antenna as it gets all kinds of abuse from hitting trees.
The flag is attached using zip ties. The flag itself was manufactured here in the USA and is a rugged flag but can not withstand too much highway speed driving.
I have only used the flag on trails and if it helps people from crashing into me then its doing its job. Also Arizona Rocks! So does its flag.
  #7
Old 06-01-2011, 06:37 AM
X-earth05's Avatar
X-earth05 X-earth05 is offline
2005 Xterra SE
Default
I don't have any pictures right now but the flag I have uses a compression fitting attaching it to the fiberglass pole and then like a npt to bolt adapter or something. You can remove the adapter and put an air quick disconnect end on it. Mount the other end on the X and taking the flag on and off becomes pretty easy.
__________________
My X
Race Team Facebook page: https://www.facebook.com/TreXterra
  #8
Old 06-01-2011, 11:36 AM
2010 Xterra X
Default
gotcha!
very innovative guys!
i'm trying to convince my dad into letting my get a firestik for the X, although he hates the idea of drilling into it at all...he's paranoid about everything...
so i know about the mount that you, fangars, make for the roof rack, but that makes clearance around the city(drive thru's, and even my drive way) a problem...
so i'm trying to do a little problem solving on my own right now...
as of now i have a magnetic mounted cb that we got years ago at radio shack...works good though...
hopefully will be able to throw a firestik on the X soon enough though..
  #9
Old 06-03-2011, 02:54 AM
Xterra1102's Avatar
2007 Altima SL
Default
They make folding CB antenna mounts too...you could keep it folded flat while in city and flip it up w/ flag on it while on the trails.
  #10
Old 06-03-2011, 04:52 AM
AZ-Ted's Avatar
AZ-Ted AZ-Ted is offline
2006 Xterra OR 4x4
Default
Here is my setup:
__________________
AZ-Ted's 2006 XOR 4x4
You may not post new threads
You may not post replies
