Difference in battery size - 24F vs 35 - Second Generation Nissan Xterra Forums (2005+)
Go Back   Second Generation Nissan Xterra Forums (2005+) > Xterra Tech Topics > Electrical
Thread Tools Display Modes
  #1
Old 03-24-2011, 10:12 AM
JasonK06X JasonK06X is offline
2006 Xterra S
Default Difference in battery size - 24F vs 35
Whats the difference with the size here? I have a choice of 24F with 700 CCA for $94.99 or a 35 with 640 CCA for $103.99.
I don't understand why the one witht he lower CCA is more expensive.
__________________
2006 Xterra S Silver "Grocery Getter" Firestone Destination A/T P265/75-16
2011 Ram 1500 Outdoorsman, quad cab, 4x4, Hemi
Old 03-24-2011, 10:18 AM
5l33p3r's Avatar
5l33p3r 5l33p3r is offline
'09 Xterra X
Default
The 24f is commonly used in toyota's and is a little bigger battery, the 35 is the standard xterra battery (I think) and is smaller than the 24f... Not sure why the price is like that?
  #3
Old 03-24-2011, 10:25 AM
2006 Xterra S
Default
By the way everyone - buy a battery at Sams Club, let your membership expire, and your battery warranty will no longer be valid! FU Sams Club!
  #4
Old 03-24-2011, 10:51 AM
Matsayz's Avatar
Matsayz Matsayz is offline
2005 Xterra S
Default
Quote:
That sounds wrong. You still paid for the battery there so it should be covered. I would make a phone call to someone besides the kid behind the desk in the automotive section...
__________________
Xterra Whaaaat!!
  #5
Old 03-24-2011, 12:00 PM
2006 Xterra S
Angry
Quote:
Every bit of it is right. Even on tires with road hazard warranty. Let the membership drop? So does the road hazard. Extended warranty on that tv? Let the membership drop, and you better hope the factory warranty is still in effect because Sams extended one is now gone.
  #6
Old 03-24-2011, 12:21 PM
masscomguru masscomguru is offline
2006 Xterra S
Default
fyi... if that is the one from advance auto, you can use the BIG35 coupon code (if it still works) and get that battery for around 65....
Thats what I just did and its a win in my book.
__________________
2006 Xterra S
Avalanche
  #7
Old 03-24-2011, 12:26 PM
2006 Xterra S
Default
Thats the coupon i just found. I'm going to order it online witht he code and go pick the thing up.
To be fair to Sams - the policy is, they will replace or repair if the product is still under the "manufacturers warranty". All other extended warranties purchased through Sams are null and void if you let your membership expire. Just a heads up for anyone looking to buy that big screen of what not and get the extended warranty with it.
  #8
2006 Xterra S
Default
So which battery did you go with from them?
  #9
Old 03-24-2011, 01:15 PM
2006 Xterra S
Default
the autocraft 24F.
fit right in, had a decent warranty, and had more cca than stock.
  #10
Old 03-24-2011, 02:26 PM
2006 Xterra S
Default
Went home at lunch and put the charger on the battery. The truck started up immediately with the charger hooked to it, but I left the charger on the battery during lunch. Within an hour, the charger brought the battery back up to 100%.
Thinking about this, I remembered that I had that ECM relay replaced just 3 weeks ago. Could that dang thing cause the car to have no power at all? No interier lights, etc?
You may not post new threads
You may not post replies
