Recommended Fluids and Capacity - Second Generation Nissan Xterra Forums (2005+)
Go Back   Second Generation Nissan Xterra Forums (2005+) > Xterra Tech Topics > Powertrain & Driveline
Closed Thread
Thread Tools Display Modes
  #1
Old 06-21-2007, 02:17 PM
kokopop kokopop is offline
Default Recommended Fluids and Capacity
Here are the recommended Nissan fluids and capacities
Engine Oil:
Type: 5W-30 Oil with API Certification
Capacity: 5 3/8 qt or 5.1 L
Cooling System:
Type: Genuine Nissan Long Lift Anti-freeze or equivalent
Capacity: 2 3/4 gal or 10.2L
Automatic Transmission:
Type: Genuine Nissan Matic S ATF (previous Matic J)
Capacity: 10 7/8 qt or 10.3L
Manual Transmission:
Type: Genuine Nissan Manual Transmission Fluid HQ Multi 75W-85 or API GL-4, Viscosity SAW 75W-85 or 75W-90
2WD Capacity: 4 1/4 qt or 3.98 L
4WD Capacity: 4 3/8 qt or 4.18 L
Rear Diff:
C200
Type: API GL-5 Synthetic 75W-90 Gear Oil or Equivalent
Capacity: 3 3/8 pt or 1.6L
M226
Type: API GL-5 Synthetic 75W-140 Gear Oil or Equivalent
Capacity: 4 1/4 pt or 2.01L
Transfer Case:
Type: Genuine Nissan Matic D ATF or DEXRON III or MERCON or equivalent
Capacity: 2 1/8 qt or 2.0L
Front Dif (Xterra R180):
Type: API GL-5 SAE 80W-90 Gear Oil or Equivalent
Capacity: 1 3/4 pt or .85L
Front Diff (Titan M205):
Old 06-22-2007, 01:10 AM
Raymond06 Raymond06 is offline
Member
Default
Thanks!
so did I mess up putting a non synthetic in my rear diff? I plan on changing it out after 3000 miles the thing that bothered me was it was almost a full pint low from the factory. I couldnt find anyone in this town with 75-140 syn I will have to order it from amsoil I just dont have the cash at this moment in time.
  #3
Old 07-04-2007, 05:25 PM
xterra4me xterra4me is offline
Default
I found that the Castrol ATF meets Nissan Matic D & J specs. I put it in my transfer case.
__________________
05 Xterra S 4x4
Lightning Silver
  #4
Old 07-04-2007, 06:31 PM
brutus_skx's Avatar
brutus_skx brutus_skx is offline
1999 Maxima SE
Default
Royal Purple ATF meets the nissan, dexron3 and mercon specs. Its what I use. Good stuff just like the amsol stuff
__________________
STEVE & Krystal Go BSU!!
2006 Xterra 4x4 (Sold); 2010 Frontier CC LE 4x4 (Sold)
"If you're not gonna pull the trigger, don't point the gun." - James Baker
  #5
Old 07-04-2007, 11:18 PM
Muzikman Muzikman is offline
2nd Godfather / Administrator
2005 Xterra Off-Road
Default
Quote:
The 05+ X uses Matic J tranny fluid, not Dexron3 and Mercon.
__________________
Muzikman
www.thexterra.org
  #6
Old 07-05-2007, 12:00 AM
brutus_skx's Avatar
1999 Maxima SE
Default
I am reffering to the transfer case kokopop said:
"Transfer Case:
Capacity: 2 1/8 qt or 2.0L "
Is this information not correct??
Cause if so I need to go and change the fluid again and I wasted 30 bucks!
  #7
Old 07-05-2007, 09:17 AM
Default
For the TC that is fine. There are a lot of Dexron3 and Mercon out there.
  #8
Old 07-06-2007, 09:44 PM
Default
The AT only use the J Matic.
__________________
-Keith
05 Brawn Red OR 6MT, Shrock Sliders and front Bumper, Black Panther Skid Plates
  #9
Old 07-06-2007, 09:49 PM
brutus_skx's Avatar
1999 Maxima SE
Default
Quote:
Whew, I was scared for a sec,
Closed Thread
You may not post new threads
You may not post replies
