P0420 Code Replacement - Second Generation Nissan Xterra Forums (2005+)
Go Back   Second Generation Nissan Xterra Forums (2005+) > Xterra Tech Topics > Powertrain & Driveline
Thread Tools Display Modes
  #1
Old 01-04-2011, 04:55 AM
rckev's Avatar
rckev rckev is offline
Default P0420 Code Replacement
So the old p0420 code is on and the dealer has quoted me $1050 to replace the cat. All of the muffler shops are saying about 800. Last nite I ordered up a new cat from auto parts warehouse for $226 delivered. Looks like my sat. will be with the wrenches. I think the hardest part will be clearing the code. Unless the new cat will make it go away
__________________
2006 S 4x4 Avalanche
Husky liners
White Grille
Amsoiled
Old 01-04-2011, 08:19 AM
macguyvermedic's Avatar
macguyvermedic macguyvermedic is offline
2008 War Machine Edition Xterra OR
Send a message via Skype™ to macguyvermedic
Default
Before I had a scanner I would just have the Auto Zone guys do it for me for free. I know their not technically suppose to do it but most of them in my experience don't have a problem doing it.
Update on how much time it takes and what truly needs to be removed to complete. Got to help a buddy with the same thing in a couple of weeks.
__________________
I love Lamp.
"If a tree falls in a forest and I'm on cruise control on another part of the planet, will my differential grenade?"
  #3
Old 01-04-2011, 08:52 AM
SPN4125's Avatar
SPN4125 SPN4125 is offline
2007 Xterra S
Default
God I hate working on the exhaust of cars, nothing is ever easy. Everything is always so rusted, Good luck.
  #4
Old 01-04-2011, 10:20 AM
xmedicG's Avatar
xmedicG xmedicG is offline
2005 Pirate X-arrgh-a
Send a message via AIM to xmedicG Send a message via Yahoo to xmedicG
Default
mine's throwing the same code. which catcon did u get from auto parts warehouse? and it's the passenger side that needed to be changed right?
__________________
"Life's journey is not to arrive safely at the grave in a well preserved body, but rather to skid sideways totally worn out and shouting: holy sh!t!! .. what a ride!!"
project: Reborn X
  #5
Old 01-04-2011, 10:24 AM
masscomguru masscomguru is offline
2006 Xterra S
Default
you can clear the code using the gas pedal. I placed a "how to" that was posted by someone else in the forum under the how to section.
__________________
2006 Xterra S
Avalanche
  #6
Old 01-04-2011, 12:55 PM
rckev's Avatar
Default
Quote:
They have a bolt on stainless it's like the 1st and 2nd one that comes up I think the number was EAST40711 for the passenger side
  #7
Old 01-04-2011, 12:57 PM
rckev's Avatar
Default
Quote:
My part wont be here till Fri. every nite before i go to bed i hit the bolts with some creep/PB Blaster I will do this every nite till I am ready to wrench. This has worked for me before. You just have to deal w/the smell for a few days
  #8
Old 01-04-2011, 12:58 PM
rckev's Avatar
Default
Quote:
Thanks I will look that up
  #9
Old 01-04-2011, 09:20 PM
rckev's Avatar
Default
well as I posted last nite the cat was ordered. Sunday I decided to pour 1/2 can of seafoam in the tank w/1/4 tank of gas I drove for about 50 miles before topping it up to full. Drove to work yesterday and today with the SES light on and would you believe the damn light went out when I cranked it up for the ride home. 100 miles and It is still off. I poured the rest of the can in after 285 miles and filled it up again. why could this not have happened before I spent 225 on a cat?
  #10
Old 01-05-2011, 07:49 AM
2006 Xterra S
Default
^^it will come back... the below the light is just coming on now because the cat is beginning to go. I can do the same with a bottle of techtron. give it a couple of thousand miles. The trigger for that particular code happens when the system sees the same issue twice in a row on two drive cycles. you can figure a normal drive cycle to be a tank of gas. When it gets really bad, the code will just come back on immediately. I drove for almost a year on my drivers side cat (i would not suggest that) but in the end, it was back on within 80 miles or so. Mine is also just beginning to go because the light will come on randomly between 1000 and 4000 miles.
You may not post new threads
You may not post replies
