Xterra wont start - Second Generation Nissan Xterra Forums (2005+)
Go Back   Second Generation Nissan Xterra Forums (2005+) > Xterra Tech Topics > Powertrain & Driveline
Thread Tools Display Modes
  #1
Old 11-04-2010, 05:06 PM
HeatShieldsMustDie's Avatar
HeatShieldsMustDie HeatShieldsMustDie is offline
2006 Xterra 6 Speed M/T 4x4 S
Default Xterra wont start
Hey all, new to the site so just want to thank everyone in advance.
My xterra gets alittle cranky (pun intended) when there is a big change in weather...mostly temperature. It will crank but not fire. About 4-5 attempts later it'll fire up and run fine. Is this a computer issue? It usually does this 2-3 days in a row and has happened several times now.
I also have a volant CAI installed which sets off the check engine light once in awhile. I've read this is common with the powercore filter. The code pulled is left bank lean.
Thanks for any tips....I love the thing when it actually starts.
Old 11-04-2010, 07:24 PM
Texterra's Avatar
Texterra Texterra is offline
2005 XTerra SE 4X4
Default
Welcome to the site my friend!
Have you checked the fuel pump. Mine had to be replaced by Nissan. I paid for it my self and it was around $350.
I had to turn the ignition switch on for a couple of seconds before i would twist the key all the way. The singal was delayed in the prior pump.
Keep looking though..
  #3
Old 11-05-2010, 03:37 PM
xterramex's Avatar
xterramex xterramex is offline
2005 s 4X2 s
Default
ipdm maybe...
  #4
Old 11-06-2010, 12:40 PM
aaron_day aaron_day is offline
Member
Default
just off the top of my head without looking at it id say ether the fuel pump or the cam sensor.. seen alot of those lately
  #5
Old 11-06-2010, 01:33 PM
Default
is that something thats covered by the powertrain warranty?
  #6
Old 11-06-2010, 01:45 PM
Member
Default
Quote:
How many miles do you have
  #7
Old 11-06-2010, 03:45 PM
Default
42,000. Apparently I have until 60k or 5 years
  #8
Old 11-06-2010, 04:27 PM
MUDLOVER55's Avatar
MUDLOVER55 MUDLOVER55 is offline
2007 Super Black Xterra X 6MT
Default
yes fuel pump is covered under powertrain
  #9
Old 11-06-2010, 04:40 PM
Member
Default
Quote:
True statement
  #10
Old 11-06-2010, 05:36 PM
Default
Thanks guys....guess theyre gonna charge me to diognose the problem. I brought it in once before, they couldnt duplicate the problem (Duh it started, I was able to drive it there) so they pretty much blew me off. Hopefully they'll just replace it.
You may not post new threads
You may not post replies
