Axle seal replacement on c200 help? - Second Generation Nissan Xterra Forums (2005+)
Go Back   Second Generation Nissan Xterra Forums (2005+) > Xterra Tech Topics > Powertrain & Driveline
Thread Tools Display Modes
  #1
Old 10-14-2010, 10:26 PM
Jspecrx7 Jspecrx7 is offline
Member
Unhappy Axle seal replacement on c200 help?
I noticed my wife's 06 Xterra S model 4x4 leaking from the passenger side rear axle seal. Its not too bad where its pooling but its enough to slop all over the inside of the rim. Looks like it just started within the past day or two. So now I'm going to take on the task of replacing it soon. Its not an offroad edition so she must have the c200 instead of the M226. So I'm going to be ordering the parts to complete the repair. So what parts will I need? According to the manual it says I need to replace the Axle bearing, bearing ring retainer, shim washer, snap ring, ABS sensor rotor, O-ring, and Axle oil seal. I have access to a press at work if I need to press any bearings out. Any help would be greatly appreciated....!!
Old 10-15-2010, 05:18 AM
Surf and Snow's Avatar
Surf and Snow Surf and Snow is offline
Go Pack Go!!!
2005 Night Armor Xterra Off-Road - Expedition Style
Default
Is it an auto trans, or manual trans? If its manual, it will have an M226 even though it isnt an off road FYI.
__________________
> My X build........(All signature links are clicky )
> My Big Overland Trip (9,467mi, 5 CAN Provinces, 22 USA states)
  #3
Old 10-15-2010, 07:51 AM
Member
Default
Thank you forgot to mention its an automatic. The 6 bolt neck confirms its a c200. If I'm reading the diagram correctly you don't have to press any bearings out or disassemble the axle to get to the axle seal? Looks like you just have to pull out the axle. Can anyone please confirm this?
Quote:
  #4
Old 10-17-2010, 03:28 PM
Member
Default
Anyone..?
  #5
Old 10-17-2010, 04:10 PM
ronaprhys's Avatar
ronaprhys ronaprhys is offline
2007 Xterra Off-Road
Location: In a burb northwest of Detroit. Enemy territory.
Default
I'm looking at the FSM and it looks like you've got to remove the axle to get to it. Honestly, I can't see how you wouldn't. You won't have to uninstall any bearings, but the FSM does recommend replacing the ABS sensor ring, though.
Not sure how necessary that is.
__________________
Build Thread. At the rate I'm going I should have an ExPo vehicle ready in roughly 6.3 years. It'll be pimpish. **Joins in 08, 6 years later he's dual lockered, RTT'ed and on schedule for his signature. Well done sir. - Surf and Snow, 5/9/14**
  #6
Old 10-17-2010, 04:59 PM
Member
Default
^ Thanks for the reply I appreciate it.
  #7
Old 10-17-2010, 09:29 PM
macguyvermedic's Avatar
macguyvermedic macguyvermedic is offline
2008 War Machine Edition Xterra OR
Send a message via Skype™ to macguyvermedic
Default
As far as I can tell the FSM only recommends you inspect the ABS sensor ring. AS long as the ring isn't cracked/warped/missing teeth and your not kicking any codes "VDC/ABS" I would call it good. You can get all of the parts from Rock Auto for about 1/3 the price, without a loss in quality.
Part # 710479
__________________
I love Lamp.
"If a tree falls in a forest and I'm on cruise control on another part of the planet, will my differential grenade?"
  #8
Old 10-17-2010, 09:42 PM
Member
Default
^ ok thanks, so the only part I will need to fix the leak is the axle seal its self. I hope I won't need the SST that they use in the manual to pull the axle/reinstall the axle and remove the seal.
  #9
Old 10-17-2010, 10:30 PM
Default
No just the part number for the seal. I have zero experience with the c200 and after rereading that section, I would have to say it's quite a bit more involved the the m226 I have. It looks like you will in fact need to replace everything just to fix that seal. If I were you I would PM Surf and Snow and get his expert opinion. He has cleared things up for before. I can't figure out why you would have to replace anything but the oil seal, but that's not my profession. Sorry I couldn't be of more help. How many miles you do you have on the old girl, extended warranty??
  #10
Old 10-17-2010, 10:58 PM
Default
Will you are at it, I would also do the breather mod, which was most likley the cause of the leak to begin with.
You may not post new threads
You may not post replies
