How-to: How to Adjust your Headlights - Second Generation Nissan Xterra Forums (2005+)
Go Back   Second Generation Nissan Xterra Forums (2005+) > Xterra Tech Topics > How-to's
Thread Tools Display Modes
  #1
Old 01-28-2006, 08:10 PM
Glucola Glucola is offline
Founding Godfather / Administrator
2011 Wrangler Unlimited Rubicon
Default How-to: How to Adjust your Headlights
How to adjust your head lights for '05+ xterras.
Before performing aiming adjustment, make sure of the following:
Keep all tires inflated to correct pressure.
Place vehicle on level ground.
See that vehicle is unloaded (except for full-levels of coolant, engine oil and fuel, spare tire, jack and tools). Have the driver or equivalent weight placed in the driver seat.
Position vehicle 25 feet (7.6M) from a wall or something similar.
Low Beam and High Beam
Note: By regulation, no means for horizontal aim adjustment is provided from the factory, only vertical aim is adjustable.
Turn headlamp low beam on.
Use adjustment screw to perform aiming adjustment.
(Adjustment screw is located next to the top bracket closest to the fender on each side).
Cover the opposite lamp and ensure fog lamps, if equipped, are turned off.
Caution: DO NOT tighten adjustment screw beyond a torque of 1.67Nm (17kg-cm, 14.8 in-lb) or damage may occur.
Adjust beam pattern until cut off line (top edge of illumination area) is positioned at same height off ground as bulb center (on H-line). Measure cut-off line within distance A on H-line.
If vehicle front body has been reparied and/or the headlamp assembly has been replaced, check aiming. Use the aiming chart shown below.
Basic illuminating area for adjustment should be within range shown on the aiming chart. Adjust headlamps accordingly.
Adjustment screws diagram.
Aiming diagram.
__________________
My Rubi
4:1 low range, Dana 44's front and Rear. Tru-LoK front and Rear. Electronic Sway bar disconnect. 73.1:1 crawl ratio
AKA our Founding Father (The Godfather)
Old 01-30-2006, 12:52 PM
defibvt defibvt is offline
Send a message via MSN to defibvt
Default
That is excellent Dan. If it is possible I would recommend being back 50 feet. I did it to my old 2000 and used both distances. At 50 feet I felt I had a better handle on where the headlights were shining.
  #3
Old 01-30-2006, 02:51 PM
Default
If that works better then cool. That's actually straight out of the service manual.
  #4
Old 01-30-2006, 03:21 PM
Default
When I did mine on the 2000, I googled for directiions but if it is out of the manual it should work well. I haven't searched the manual for that particular info.
  #5
Old 01-30-2006, 03:25 PM
Default
Yeah someone on XF asked if anyone knew how to do it so I just looked it up on my laptop and copied it right over.
  #6
Old 02-08-2006, 01:37 PM
usmc xterra's Avatar
usmc xterra usmc xterra is offline
Default
Get a kick out of this,
I was wondering why you posted that. Such new vehicles and all.
Until I did the lift and went for a ride shinning my lights into everyone's eyes. Now I can use these directions. Gotta wait to get the back done, if the Cops don't get me before that.
MC
__________________
http://i34.photobucket.com/albums/d1...a/Flagc301.gif
http://www.myspace.com/mcthexmodman
http://www.myspace.com/usmcmikes
Experience is a tough way to learn, because you get the test first...and the lesson afterwards. MC
  #7
Old 12-11-2006, 03:00 PM
dragonplayboy dragonplayboy is offline
Default
what would the ideal height off the ground at 25 and 50 feet be? I can't decipher it...
  #8
Old 12-14-2006, 08:30 AM
Default
I went to do this last night and couldn't find the adjustment screw for the life of me!! also, is clockwise down or up?
Thanks!!
  #9
Old 12-18-2006, 12:45 PM
Default
  #10
Old 12-20-2006, 07:56 PM
epor's Avatar
epor epor is offline
Member
Default
FYI, this is not the same in the 2006. Well, at least in my 2006. There is a 8mm hex nut near the bottom of the headlight closest to the fender that has a metal washer that looks like it has teeth.
I decided I needed to adjust them when I could see people getting blinded in their rear view mirrors and when people would come up behind me after I passed them on the highway and they would put on their high beams on purpose. Some people...
You may not post new threads
You may not post replies
