How-to: RESET ECU/Check Engine Light w/o Battery Disconnect - Second Generation Nissan Xterra Forums (2005+)
Go Back   Second Generation Nissan Xterra Forums (2005+) > Xterra Tech Topics > How-to's
Thread Tools Display Modes
  #1
Old 04-08-2007, 05:59 AM
ahnyoungboi3 ahnyoungboi3 is offline
Send a message via AIM to ahnyoungboi3
Default How-to: RESET ECU/Check Engine Light w/o Battery Disconnect
ok.....sooooooo i dont think anyone on this board has realized that nissan made it possible to reset the ecu w/o having to disconnect the battery and without the use of a scantool.
so this is how you reset the engine ECU
i had to reset becuase i cleaned the TB throttle body and i messed up the idle control sensor.checkengine light came on.....
i sat in the car for like 40 mins trying to remember how i reset the maxima ecu......finally remembered....here it is.
1.)turn the key to the on position (do not crank over the motor....dont start the engine)
2.) wait 3 seconds.... and then fully step on the gas and let go fully 5 times with in 5 seconds....
(ex. wait...3....stomp.stomp.stomp.stomp.stomp
3.)wait 6seconds....(not steppig on gas pedal)
4. FULLY PRESSS down on gas pedal and hold for about 10 seconds.
5.) the check engine light should be flashing.
should be flashing 10times and stop a few seconds and then 10 and stop.....etc.
6. hold down pedal again 10 secs.
7. release pedal.....turn key off.....
8...wait a few seconds and turn the motor on.....check engine light should be gone.
i think dan should sticky this.
Old 05-10-2007, 01:59 AM
lowhombre's Avatar
lowhombre lowhombre is offline
2007 Xterra X
Default
good to know...
__________________
X
  #3
Old 11-14-2007, 11:34 AM
Jasontamu Jasontamu is offline
2008 Xterra X
Send a message via AIM to Jasontamu Send a message via Yahoo to Jasontamu
Default
good lord......i would have never thought thats how you do it....
- j
  #4
Old 11-14-2007, 12:11 PM
miles miles is offline
Default
thanks...
__________________
My Xterra
http://www.thenewx.org/phpbb2/viewtopic.php?t=10253
________________________________________
All service and installation courtsey of Krown lakeshore
http://www.krown.com/lakeshore/
  #5
Old 12-20-2007, 11:04 AM
Atom's Avatar
Atom Atom is offline
2006 Xterra S
Default
is this legit?
  #6
Old 12-20-2007, 11:24 AM
JIMBO's Avatar
JIMBO JIMBO is offline
2008 JEEP wrangler Unlimited Rubicon off-road
Send a message via MSN to JIMBO
Default
Well, thats very convenient, BUT
--WHAT IF SOMETHING ----IS----WRONG--
--In that case, you're just delaying catastrophy !!!!
--Sorry
-- --JIMBO
__________________
-'08 JEEP RUBICON JK
--Man, you gotta have "style"
  #7
Old 12-21-2007, 10:39 PM
k1w1t1m k1w1t1m is offline
Default
--Sorry
-- --JIMBO
If something is wrong the light will come back on. In which case you know to take it in and get the codes read.
__________________
'07 4x4 Midnight Blue, straight out of the box.
  #8
Old 12-25-2007, 05:32 PM
Default
yea....its legit...try it out....and i agree w/ kiwi
  #9
Old 12-26-2007, 02:57 AM
Peck's Avatar
Peck Peck is offline
2007 Frontier SE 4x4
Default
Good info to keep on hand..Ctrl D it is!
Nissan and their funky ways of resettig things, like the air bag lights. Oh well, rather do this than spend the cash to have the dealer clear them.
  #10
Old 06-17-2008, 02:27 PM
iepeulas iepeulas is offline
Noobie
Default
Is it like the Nissan sentra and the number of times the SES light flashes is the OBDII code?
edit: here's a link
http://www.b15sentra.net/forums/showthread.php?t=76692
edit: more info:
Further research indicates that you can indeed pull the code with no tool using this technique. The first flashes are slow, This is the first flashes are the first number in the code (thousands column). The groups of faster flashes coorespond to other numbers in the code. Between each number in the code, there is a pause. Ten flashes equals a zero.
http://www.nissanhelp.com/diy/common...des_read_2.htm
__________________
Jeremy in New Haven
2005 Xterra S 4x4 6 spd - Stock
1984 Honda V30 Magna
You may not post new threads
You may not post replies
