Service Engine Soon Light, Reset? - Second Generation Nissan Xterra Forums (2005+)
Go Back   Second Generation Nissan Xterra Forums (2005+) > Xterra Tech Topics > Electrical
Thread Tools Display Modes
  #1
Old 03-24-2010, 06:47 PM
Scungi's Avatar
Scungi Scungi is offline
Member
Default Service Engine Soon Light, Reset?
I checked out the other threads, and seeing alot of people having issues with the FSU, needing to be replaced.
Is there a way other then getting the code red, to reset the SES light and make sure it is something more then the gas cap?
I was there at the dealerships two weeks ago, states it was pointing to the gas cap, checked it a few times and filled up again, light is still on?
Old 03-24-2010, 07:33 PM
XKNUT's Avatar
XKNUT XKNUT is offline
Default
Yes there is.
You turn the key to ON but not start and depress the gas pedal a certain number of times within a time frame then count the flashes.
I'll check the exactlies and get back to ya.
Here you are:
How to read the engine codes without a Nissan CONSULT or scan tool. (Set ECM in Diagnostic Test Mode II)
  1. Confirm that accelerator pedal is fully released, turn ignition switch ON and wait 3 seconds.
  2. Repeat the following procedure quickly five times within 5 seconds.
    1. Fully depress the accelerator pedal.
    2. Fully release the accelerator pedal.
  3. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 10 seconds until the MIL starts blinking.
  4. Fully release the accelerator pedal.
  5. ECM has entered to Diagnostic Test Mode II (Self-diagnostic results).
From this page:
http://www.nissanhelp.com/diy/common...des_read_2.htm
__________________
2005 Grey OR MT
Radflo Coilovers, 750# Eibach Springs. Deaver AAl w/Bilstein 5125s.
FUGreenpeace
  #3
Old 03-24-2010, 08:35 PM
Webfur's Avatar
Webfur Webfur is offline
2007 Xterra X
Send a message via AIM to Webfur
Default
Disconnect the battery!
  #4
Old 03-24-2010, 09:04 PM
Chug's Avatar
Chug Chug is online now
2007 Xterra SE, 4 X 4
Default
IN all the wisdom of Big bucks going into building a Auto.. They come up with Press Gas pedal while Toggling the key in & out.. back & fourth.. eh... WTF!!. Why so complicated?.
Why do they just add a Key pad. Or button with up & down arrows to cycle a simple Menu. Or it's the plan to keep money into service bay's Vs. home fixing?
Shesh. All that pressing of the Gas pedal.. hmmm.. Sounds like a toyota Sticking gas pedal soon... :-)
Scan tool will be simpler.
Dunno.. just had to wonder... on that one
__________________
Never give up the high Ground!!
" A man who wouldn't cheat for a poke don't want one bad enough. "
Gus McCrae-
  #5
Old 03-26-2010, 02:22 AM
LINE-OF-FIRE's Avatar
LINE-OF-FIRE LINE-OF-FIRE is offline
2006 XTERRA 4X4 S
Default
Chug if it was easy you might want to fix it yourself, and not bring it to a Nissan dealer.
  #6
Old 03-26-2010, 02:30 AM
Xterra1102's Avatar
Xterra1102 Xterra1102 is offline
2007 Altima SL
Default
Any autozone or advance auto parts will clear a check engine light for free. Just go in and ask.
  #7
Old 03-26-2010, 12:02 PM
XKNUT's Avatar
Default
State specific. Not here in CA.
Thank you Barbara Boxer.
  #8
Old 03-26-2010, 12:16 PM
Xterra1102's Avatar
2007 Altima SL
Default
Really?!? Wow that's dumb!
Well then get a Superchips Cortex hehehe
  #9
Old 03-26-2010, 05:23 PM
Peck's Avatar
Peck Peck is offline
2007 Frontier SE 4x4
Default
Remove negative cable.
Touch it to positive terminal -- with positive cable still attached.
Hold for a few seconds, I usually do 10.
This will drain the capacitors in the truck and reset the light(s).
  #10
Old 04-04-2010, 11:35 PM
Scungi's Avatar
Member
Default
OK ended up at the dealership. Evap sensor (4056?, all points were thinking gas cap). Had to replace the sensor. They also did the recall fuel work as well.
Got it back, light came on again.......had to update the updated sensor? It is fixed now, just a lil bizarre
You may not post new threads
You may not post replies
