Grinding noise - Second Generation Nissan Xterra Forums (2005+)
Go Back   Second Generation Nissan Xterra Forums (2005+) > Xterra Tech Topics > Powertrain & Driveline
Thread Tools Display Modes
  #1
Old 12-30-2009, 12:59 AM
Redbrawn06's Avatar
Redbrawn06 Redbrawn06 is offline
Member
2005 Xterra Off-Road
Question Grinding noise
Hey,
I have a 6spd man transmission and recently ive been getting a strange grinding noise. It happens in every gear after about 2500 rpm's. If i shift it goes away until, you guessed it, i hit 2500 RPM's again. does anyone know what it is?
Old 12-30-2009, 06:47 PM
alkeli's Avatar
alkeli alkeli is offline
2015 F-150 XLT Sport FX4 SuperCrew
Default
Does it happen even when you're coasting at 2500RPM's? Is it worse when you give it gas? Could be something as simple as something rattling around somewhere...
__________________
Ford F-150 XLT Sport SuperCrew . FX4 . 4x4
  #3
Old 12-30-2009, 07:09 PM
cynicroute's Avatar
cynicroute cynicroute is offline
2008 Xterra Off-Road (6sp)
Default
In 2WD or 4WD - or both?
__________________
08 Off-Road | Knight Armour | 6 Speed Manual | HID Bi-Xenon headlights | LED Tail, Signals, and Interior lamps | Hella 500FF (with HID retro) | Custom Fab front light bar
  #4
Old 12-30-2009, 10:02 PM
Redbrawn06's Avatar
Member
Default
Its both it happens when its in 2 High. But yeah It is worse when i give it gas. Thats mainly when its noticeable.
  #5
Old 12-30-2009, 10:40 PM
Rook's Avatar
Rook Rook is offline
2007 Xterra K.H.A.O.S. Edition
Default
where does it come from or seem to come from..how loud is it....many phones can now take sound clips...or video clips..can you upload one? it would help us diagnose your problem.....does the sound seem to come from a certain side of the truck...or the middle?
you may have a bad torque converter....however, this is incredibly rare on these trucks...
__________________
The Great Ninja of the East
Project K.H.A.O.S.
  #6
Old 12-31-2009, 07:09 AM
masscomguru masscomguru is offline
2006 Xterra S
Default
Check out this post. Is the noise you have similar? A lot of us have this same noise. http://www.thenewx.org/forum/showthr...light=2200+rpm
__________________
2006 Xterra S
Avalanche
  #7
Old 12-31-2009, 07:25 AM
CanadianX's Avatar
CanadianX CanadianX is offline
2006 Knights Armor Xterra Off Road
Default
I had a rattle, seemed to be RPM specific - turned out to be a rock vibrating on top of the skid, easy fix. Hope yours is something as simple, seems like the above is a good lead.
  #8
Old 12-31-2009, 09:03 AM
Rook's Avatar
Default
yes i agree the above post sounds very promising....but if you could capture a video or sound clip of it..I'm sure somone on this site could give you a better idea of what it is.
  #9
Old 12-31-2009, 11:06 AM
AZX AZX is offline
Noobie
2005 Xterra S
Default
Here's my two cents' worth. I also have a 6-speed, have heard a rattling noise while accelerating. Seems to go away if I just barely put pressure on the clutch pedal.
I think I've found a likely candidate. There is a pin that connects the clutch pedal lever to a clevis that most likely goes into the clutch master cylinder. (see arrow in pictures below)
When the clutch is fully released, there is no pressure on this pin. The holes in the pedal lever and clevis are slightly larger than the pin, which allows the pin to rattle.
The mechanism is set up this way so that there is zero pressure being applied from the clutch pedal to the clutch master cylinder when the clutch is released. Any residual pressure being applied could potentially cause clutch slippage, premature clutch wear, so on and so forth.
I don't think there's anything wrong with having the pin rattle, it's just annoying. That being said, I'm also trying to figure out how to get it to stop...
  #10
Old 12-31-2009, 11:28 AM
BMPSKIR's Avatar
BMPSKIR BMPSKIR is offline
2005 Xterra X
Send a message via ICQ to BMPSKIR
Default
duct tape fixes all.... or pull it out, wrap some electrical tape around the pin, then put it back in...
__________________
Live Free or Die...
You may not post new threads
You may not post replies
