Heater problem - Second Generation Nissan Xterra Forums (2005+)
Go Back   Second Generation Nissan Xterra Forums (2005+) > Xterra Tech Topics > Interior
Thread Tools Display Modes
  #1
Old 10-06-2009, 11:20 AM
weedwacker13 weedwacker13 is offline
Member
2006 Xterra S
Default Heater problem
I just put in my 3" body lift, and I seem to have a few casualties. As of right now I have no heat or ac. The AC is explained, because I forgot to unclip my high pressure sensor before stretching it out, and breaking it. That part got ordered today. However, my heater is not working, which is something I can not figure out. The hose going into my heater core is hot, but the one coming out is not. My fans work, but seem to blow the same temp, no matter what the setting. I have checked for any uncliped wires, that I might have forgot to reconnect, and cannot seem to find any.
Any suggestions would be greatly appreciated. BTW my xterra is a 2006 S 6spd.
Thanks,
Jesse
Old 10-07-2009, 04:29 PM
MdPhoenix MdPhoenix is offline
2006 Xterra S/MT
Send a message via ICQ to MdPhoenix Send a message via AIM to MdPhoenix Send a message via MSN to MdPhoenix Send a message via Yahoo to MdPhoenix
Default
I haven't checked out the heater core on my X yet, but years ago, there was a vacuum valve connected to one of the heater core hoses. When you switched the system to "heat", the valve opened allowing hot water to flow through the core and have heat exchanged via air flow. The vacuum hose connecting to my valve had broken and I had the same problem. I'm guessing these days it's an electronic valve? Either way, is there some sort of control box or valve on one of the heater core hoses?
  #3
Old 10-07-2009, 04:31 PM
ricerconvert's Avatar
ricerconvert ricerconvert is offline
2005 Xterra Titan Swapped Off-Road
Default
^^^^^^ That would be my bet. I dont know what kind of valve the X has on the heater core, but thats about the only thing that can go wrong with heater cores.
__________________
Sadie
  #4
Old 10-07-2009, 11:14 PM
Member
2006 Xterra S
Default
At first I too was looking for this vacume line to open the valve, but after a little thought, and a few beers, it ended up being something much simpler than that. After removing and refilling the radiator for the lift, we had forgoten to "burp" the system of any air pockets. I didnt think that a little air would have so much of an effect as to not produce any heat at all, but apparenty I was wrong.
Now the only thing left to fix from the body lift is my fuel filler neck, something I have not even looked into yet, but I dont expect much trouble from.
Thanks for everyones help.
Jesse
  #5
Old 10-08-2009, 08:13 AM
2006 Xterra S/MT
Default
Good stuff. Thanks for the solution!
  #6
Old 11-07-2009, 11:30 PM
yurib yurib is offline
Noobie
2006 Xterra S
Default
Quote:
How exactly do you "burp" the air from heating system?
I have a small problem with my heater: it heats OK at higher RPMs, but at idle speed temperature drops. I was told this might be caused by some air pocket in the system.
  #7
Old 11-08-2009, 08:31 AM
gpzguy's Avatar
gpzguy gpzguy is offline
2008 Xterra SE
Default
Generic method for just about any vehicle: Park it so your facing uphill slightly. Make sure that its cooled down, then pull off the radiator cap. See how much air volume is down the radiator neck. Add coolant. Put the cap back on, then find the fat hoses going to the radiator and squeeze them a couple dozen times in different places. Pull off the radiator cap and check again. Start it up and run it for a bit with the cap off, checking level constantly with the cap in hand, and put the cap on quick once you see the level rise up into the neck, shut it off, let it cool a bit, squeeze the hoses some more, then pull the cap again and check it again. Repeat as necessary. There shouldnt' be any air in the system at all. Any expansion of the coolant due to heating makes the radiator cap lift and the excess coolant go into the expansion tank, and when it cools it creates a vacuum that (slowly) draws coolant back in from the expansion tank. The only air gap in the system is in the expansion tank.
__________________
"On the Plains of Hesitation bleach the bones of countless millions, who, at the Dawn of Victory, sat down to wait, and waiting--died!"
My 2008 SE
  #8
Old 11-08-2009, 08:52 AM
gpzguy's Avatar
2008 Xterra SE
Default
Quote:
No such animal on the Xterra heater core per the FSM. Heated coolant is always flowing through the heater core when the engine is running. What determines how much of that heat is transfered into the passenger cabin is the position of air flap doors in the heater and cooling unit. This is actually pretty standard in Japanese vehicles I've noticed.
  #9
Old 11-15-2009, 02:08 AM
BlackTigerSE's Avatar
BlackTigerSE BlackTigerSE is offline
Default
Jesse
OH!!! That explains why my heater/ac didn't work for a couple of days!
You may not post new threads
You may not post replies
