well got everything tested
first off : i like the quality of the BTF cover better than the
ballistic , the welds are cleaner and it fits nice
2nd: both covers need to have the sides of the ring ground down so they can clear the carrier bolts
3rd: the
ballistic fab cover sticks out further than BTF
4th : BTF drain plug is higher
after test fitting the
ballistic fab cover did not fit , i could get all the holes lined up but turns out why the last one wouldnt fit is because the cover was hitting the ring gear
i will let Allan know but ballistics cover is not ready to be bought
inside cover of the
ballistic , the ring gear was hitting the cover
the BTF cover you can see the difference on the bottom of the cover
