Do I Need to Jack Up the Truck to Replace Shocks? - Second Generation Nissan Xterra Forums (2005+)
Go Back   Second Generation Nissan Xterra Forums (2005+) > Xterra Tech Topics > Suspension & Steering
Thread Tools Display Modes
  #1
Old 07-29-2009, 04:44 PM
silverflash's Avatar
silverflash silverflash is offline
Default Do I Need to Jack Up the Truck to Replace Shocks?
Just got my bilsteins in. Want to install but am not sure if I need to jack the rear up or not. If so, do i jack up from the axle (jack point right behind both wheels) or the frame? I am thinking I don' thave to jack at all but am not too sure what's going to happen when i undo one bolt.
thanks...
last vehicle i did shocks on- 88 bronco- required no jacking...
__________________
2007 S 4x4 silver lightning- "BaseCamp" Edition
OEM fog lights,Nissan Bug Deflector,Nissan Seat covers,Trident white a/c unit mod
Rear Timbrens,Flexible mudflaps, GY DuraTrac 265/75R16 C-rated,bil 5100 shocks front/rear
K&N 57-6014 FIPK,Flowmaster 40/custom y-pipe, vistapro radiator, bully dog GT
Old 07-29-2009, 04:47 PM
Zuiu Zuiu is offline
Noobie
Default
From what I've been reading cause I have to replace my shocks, yes you need to jack it, and I believe with the frame.
  #3
Old 07-29-2009, 05:07 PM
Muzikman Muzikman is offline
2nd Godfather / Administrator
2005 Xterra Off-Road
Default
To replace rear shocks you do not need to jack up the car.
__________________
Muzikman
www.thexterra.org
  #4
Old 07-29-2009, 05:09 PM
Mark's Avatar
Mark Mark is offline
Send a message via AIM to Mark
Default
Nope, no jacking needed. Just small hands to do the one on the passenger side.
  #5
Old 07-29-2009, 05:11 PM
RIXterra's Avatar
RIXterra RIXterra is offline
2002 Xterra SE
Default
Quote:
You don't need to jack it up front to remove the coilover? I would imagine you would have too.. I could be wrong and not thinking correctly.
__________________
2009 Cube SL Chrome Silver
2002 SE Super Black(heavily moddified)
2005 SE Avalanche(stock) (R.I.P.)
  #6
Default
ok, i just went out and compared the new shock (bilstein 5100 for 2007 4wd xterra) to the one that is on there now- stock. The new one is like 3 inches longer. I couldn't compress it by hand but i didn't overdo trying. Will it compress? Aren't those bils adjustable? They have a black boot on the top of them, so maybe there is a way to take that off and adjust down? These shocks are for 0-3inches of lift according to the specs on the shockwarehouse site.
won't have time to do it now, maybe tonight- have a date. :-)
  #7
Old 07-29-2009, 05:37 PM
5l33p3r's Avatar
5l33p3r 5l33p3r is offline
2009 Night Armor Xterra X
Default
leave the boot on, its there to protect the shocks piston rod... as for the length difference, if you were compairing it to a factory shock that is installed on your xterra then the installed shock should be shorter due to the fact that it's in a semi compressed state (in order for the suspension to cycle). oh yea, and don't worry about not being able to compress the 5100 easily, it takes a bit of "Grunt" to get it started but once you do you shouldn't have a problem. hope it helps.
-travis
__________________
Click Here for > 5L33P3R: The Little Grey Armadillo...
  #8
Old 07-29-2009, 05:49 PM
XterraPA's Avatar
XterraPA XterraPA is offline
Super Moderator / Middle Atlantic Regional Moderator / (GPAX) Club Moderator
2005 Super Black Xterra S
Send a message via AIM to XterraPA Send a message via Yahoo to XterraPA
Default
You do not need to jack up the truck to remove or replace the REAR shocks. The front shock would require the truck to be jacked up to remove the tires.
__________________
Stephen Q. Breslin - The Beast from the East
'05 - Super Black "S" 4x4 - 6MT
www.gpaxterras.org GPAX Founder/ El Presidente - "A man of the people!"
  #9
Old 07-29-2009, 06:08 PM
xterrock xterrock is offline
Default
Quote:
keyword in this thread: rear
  #10
Old 07-29-2009, 11:20 PM
Default
yikes!!!!!
so i see that the shocks compress as one of you stated with some grunt but I cannot for the life of me get the lower shock bolts to loosen up. I tried a breaker bar, nothing. I am soaking with wd-40, that's all i have. I figure I will drive it tomorrow and maybe that stuff will works its way in to help loosen tomorrow night?
anyhow, the fsm says 148 ft/lbs but geez!! She won't budge and the bolt/nuts looks brand new...... Are they always this hard to loosen?
You may not post new threads
You may not post replies
