  #1
Old 07-19-2009, 10:44 PM
IZVERG's Avatar
IZVERG IZVERG is offline
-Resident Gimp-
2005 Xterra Titan-swapped S
Send a message via AIM to IZVERG Send a message via Yahoo to IZVERG
Default Titan Swapped!
So yeah, Mad Maxx and I started my Titan swap this morning. Started at 9:30 and stopped around 6:30 w/ the passenger PRG Titan UCA and stock Titan LCA installed, driver's stock LCA removed, partial removal of PRG X UCA, and both 2.0 Rads removed. Ran into some drama w/ those dame camber bolts seizing inside the bushings, wound up cutting them off! All the build pics so far:
The goodies.
Wow, what a difference!
Empty nest syndrome kicking in.
Break for lunch.
F you LCA, f you.
Bye-bye crap!
R180 was cracked A LOT more than I thought!
What we did get in... stock Titan LCA and PRG Titan UCA (can't see it, but it's in!).
Here's a question, would I be okay if I used a bolt one size down on the ball joint mount, or bore it out to go to a one size bigger 9/16 bolt? We had to sawzall the ball joint stock bolt out on the passenger side. Seen here, stock bolt is in the middle and 9/16 is to the left:
Will finish w/ the full Titan drivetrain/suspension swap up front, AMSOIL oil change, AMSOIL Sever Gear in the M205, 2" wheel spacers for the back to match up the new wider stance up front, rear Timbrens, and (finally) installing my t-case skid. Will also be trying to squeeze in some painting (front grill, back quarter panels, and side molding - going w/ a nice textured, flat black rattle can).
UPDATE 7/20/09
Pics of today's progress...
All bolted up!
Severe Gear for the new M205.
2" wheel spacers for the rear.
All done!
Will post up pics tomorrow after the alignment to get more dead-on shots of the new stance.
  #2
Old 07-20-2009, 10:16 AM
IZVERG's Avatar
-Resident Gimp-
Default
Well, let's hope today goes a lot smoother and I can post up the end result...
  #3
Old 07-20-2009, 11:52 AM
Jasontamu Jasontamu is offline
2008 Xterra X
Send a message via AIM to Jasontamu Send a message via Yahoo to Jasontamu
Default
nice.........in for the final result..
-J
__________________
08-X MODEL-4X4-WHITE-MB PREDATORS-AVIC-D3-VALLEY HITCH-BFG AT-PRG AAL REAR, TG SPACER FRONT-SHROCKWORKS SLIDERS-OEM FOGS-IT WILL NEVER END.......
  #4
SAMI's Avatar
SAMI SAMI is offline
Supporting Member
2006 Xterra S
Default
Jealous
__________________
Forget 'Twitter', i'm on the CB...
Cruiser Outfitters
Utah Firearm
Expedition Utah
  #5
Old 07-20-2009, 12:22 PM
LA RANA's Avatar
LA RANA LA RANA is offline
live hard wheel hard
2005 Xterra Off Road
Wink You sure can blow them
"R180 was cracked A LOT more than I thought!"
Damn...and I thought mine had a bad crack!!
__________________
LA RANA
Tread Lightly, United Four Wheel Drive Association, Virginia Four Wheel Drive Association, TheNewX, NOAS, NORA, NOR, VA4X4, VAXC, GPAX, CX, CF, TT, Big Dogs Offroad
  #6
Old 07-20-2009, 12:24 PM
maXTERRA's Avatar
maXTERRA maXTERRA is offline
Supporting Member
2006 Xterra S
Default
Pretty cool Chase!
Like to be doing mine too (eventually...)
Compliments on the beverage choice. I LOVE Rolling Rock!
  #7
Old 07-20-2009, 12:46 PM
SAMI's Avatar
Supporting Member
2006 Xterra S
Default
  #8
Old 07-20-2009, 12:54 PM
maXTERRA's Avatar
Supporting Member
2006 Xterra S
Default
Quote:
Originally Posted by SAMI View Post
For sure!
Just waiting to take a huge bite out of your wallet!
  #9
Old 07-20-2009, 02:15 PM
SeXterraPA's Avatar
SeXterraPA SeXterraPA is offline
The Beast Returns!
2005 Xterra S
Send a message via AIM to SeXterraPA Send a message via Yahoo to SeXterraPA
Default
Jeeze Louise Chase!
Too much skinny pedal.
__________________
Stephen Q. Breslin
'05 Super Black S 4x4 6MT
The Beast from the East
  #10
Old 07-20-2009, 03:14 PM
IZVERG's Avatar
-Resident Gimp-
Default
LOL, love that R180 Monster!
Had to stop due to rain today, looking better though, hoepfully we can get back out there and finish 'er up today.
Got the UCA's, LCA's, and Rads installed, tie-rod extensions on, M205 is in, passenger side axle is in, just need to get the driver's axle in, rear wheels spacers on, and off to Firestone for alignment!
  Second Generation Nissan Xterra Forums (2005+) > Xterra Tech Topics > Xterra Projects
You may not post new threads
You may not post replies
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright ©2006 - 2010, www.thenewx.org
