  #1
Old 06-04-2009, 11:55 PM
IZVERG's Avatar
IZVERG IZVERG is offline
-Resident Gimp-
2005 Xterra Titan-swapped S
Send a message via AIM to IZVERG Send a message via Yahoo to IZVERG
Default Superchips has me stranded!
So stopped for gas and put in 93 in prep for tow package tune with my Superchips. No good, I get some error that says "Call Superchips" but it's like 7 pm on the west coast. Now my engine turns but then nothing. And when I plug the programmer back in it gets stuck on "turn ignition to ON" screen. Stranded at a Valero on I 35!!! TX will not let me go!!!!!!!!!
  #2
Old 06-04-2009, 11:56 PM
IZVERG's Avatar
-Resident Gimp-
Default
Oh, and already tried disconnecting neg terminal and same dealio.
  #3
Old 06-05-2009, 12:10 AM
Dakorlord's Avatar
Dakorlord Dakorlord is offline
2007 S
Default
After the problem I had man I never program it anywhere but my house Sorry about having the proplem.
__________________
2007 Nissan Xterra,Radflo 2.5 coilovers,Prg Upper control arms's,Prg/deaver AAL pack,Prg rear shackles,bilstien rear shocks,Rear diff tube ext,Body side moldings,Air compressor under seat,285/75/16 Firestone Destination MT's, Curt rear recevier with D ring hitch,KMA front bumper,Shrock skids.
  #4
Old 06-05-2009, 12:13 AM
IZVERG's Avatar
-Resident Gimp-
Default
See though it worked fine this morning when I went from Mileage XS to 87 tune. It screwed up whenever I just now tried to upload the Light Tow option. Gahhhhhhh!
  #5
IZVERG's Avatar
-Resident Gimp-
Default
Quote:
How did you fix your problem?
  #6
Old 06-05-2009, 12:46 AM
jeff_redx's Avatar
jeff_redx jeff_redx is offline
Supporting Member
2009 Xterra Off Road
Default
Sorry about your problems, maybe this can help.
From the thread, http://www.thenewx.org/forum/showthread.php?t=18113 .
I had that same code and I unhooked my battery for an hour and went back and the programmer finally rebooted the stock tune and havnt had a problem sence.
Quote:
Originally Posted by Scott@Superchips View Post
The programmer will go into a recovery mode and return your vehicle to stock provided that you have enough voltage to do so.
The most common issue we have had is related to a low battery at the time of tuning or the existance of accessories being connected to the vehicle drawing power while attempting th tune. The programmer needs a constant 12 volts to complete its job.
If you have a look at this link http://www.thenewx.org/forum/showthr...ght=superchips you will see a post I just released days ago going over our latest update that has upgrades to the recovery too as well as the installation software that might be something that could help you here. Before you return the PCM and programmer to us see if these updates help you any.
If you are unfamiliar with our internet update software please follow this link to our web page where you can download the software to your PC: http://www.superchips.com/update_your_tuner.php
When you attempt to program the vehicle once more please make sure that you have all factory and aftermarket accessories in the vehicle turned off before programming.
If I can be of any further assistance please let me know.
Scott
Jeff
  #7
Old 06-05-2009, 01:15 AM
Dakorlord's Avatar
2007 S
Default
I would say Try and update that may help like I said on a diffrent post I had so many frinken codes poping up and my truck turned over but would not start and the cortex would not reboot and install the stock file and being it was a weekend and 8pm I thought Id try and disconnect the battery for an hour and then hooked back up and the cortex rebooted and installed the stock file. It may or may not work for you.
  #8
Old 06-05-2009, 01:55 AM
Creek's Avatar
Creek Creek is offline
Satan is my motor
2007 Xterra S Model
Send a message via AIM to Creek
Default
all this talk lately about SC causing headaches for people is making me really reluctant to purchase one.
__________________
My X
Asteroid crashed and nothing burned - made me wonder, do tigers sleep in lily patches? do rhinos run from thunder?
  #9
Old 06-05-2009, 03:03 AM
kschneider7's Avatar
kschneider7 kschneider7 is offline
2005 Xterra S
Default
Same here, I walk enough at work and I hate to pay for tow trucks!!!!!
  #10
Old 06-05-2009, 05:25 AM
Peck's Avatar
Peck Peck is offline
[insert something witty]
2007 Frontier SE 4x4
Default
I've tuned my truck in the most random of places. Gas stations, parking lots, beach, midget strip club, house, friend's house, yada, yada, yada. Never once did it give me a problem.
How's your battery doing? The tuner needs a full charge off the battery to do its thing, it takes up some juice to do so. I make sure I've run my truck for a bit and turn EVERYTHING off. Radio, lights, radar detector, pump for blow up doll, power inverter, cell phone charger, and I even make sure my door is closed and the cargo light is off before I tune. The battery is the main culprit for most people who have tuning problems. Either the battery is weak or something is draining on it.
Again, I have never had a problem tuning my truck in the most random places and leaving me SOL.
__________________
Mods, I got mods. Which means also means I have no money.
4x4 when pressing Shift is $X$. Coincidence? Probably not.
  Second Generation Nissan Xterra Forums (2005+) > Xterra Tech Topics > Electrical
You may not post new threads
You may not post replies
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright ©2006 - 2010, www.thenewx.org
