12-09-2008, 03:59 PM
-Resident Gimp-
2005 Xterra Titan-swapped S
FireStik Firefly installed on front Shrock bumper
12-09-2008, 04:06 PM
Rather Be Wheeling
2005 Xterra S
Sweet install Chase!!
Administrator
2005 Xterra Off-Road
The only issues I see with that are.
It sticks so any brush against a tree, rock or dirt (if you are in a rut) will rip it off.
The connector is exposed.
12-09-2008, 04:22 PM
-Resident Gimp-
Yeah, I had a hard time figuring out where exactly on the bumper I wanted to put/where it would fit. I was originally thinking to put it so that the pug-in would be behind the far back corner of the bumper, basically facing to the inside of the wheel well. But then I thought it might rub under full stuffage. I was wanting to see how/where you had yours, Jason, but your site was always down and I couldn't get a good look at your install spot!
Oh, and I am trying to come up w/ something (cable skid?!) to put around and cover the connector to avoid damage.
12-09-2008, 04:52 PM
Administrator
I never had any pics of the antenna install.
Basically, mine is on the passenger side and the hole is right about where the steel logo is on your mounting bracket.
12-09-2008, 04:55 PM
Administrator
This is about as good of a picture as I have.
12-09-2008, 04:56 PM
Life is Good
08 Xterra SE
yeah...can't you just drill a 1/2" hole and use the bumper as a mounting bracket? no official bracket needed....
__________________
You have to be involved to evolve.
My Xterra
12-09-2008, 04:57 PM
-Resident Gimp-
Ahaa, I see. What did you use to mount it? I don't see a mounting tab or anything.
12-09-2008, 05:02 PM
Administrator
The bumper.
I just drilled a hole in the bumper, stuck the stud mount through and tightened it up.
I did have to isolate the stud mount with a piece of shrink tube since the bumper is thicker than a normal mount.
The reason I mounted it to the passenger side is for two reasons.
1. I don't look right into it when driving.
2. I use it to judge the right corner. If the antenna is going to get past the obstacle, the bumper will too. (It's easier to judge the drivers side.)
12-09-2008, 05:25 PM
Life is Good
08 Xterra SE
...and you won't hit the awning of a drive thru fast food place when it's on your passenger side.
| Thread Tools |
| Display Modes |
Linear Mode
You may not post new threads
You may not post replies
Powered by vBulletin® Version 3.7.3 Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright ©2006 - 2010, www.thenewx.org The Nissan names, logos and slogans are registered trademarks of Nissan Motor Co. Ltd and is no way affiliated with this site. All posts are the property of the posters and are not the responsibility of thenewx.org, it's affiliates, web hosts or associated companies.
