What should I use to cover the holes in the soft 8's? - Second Generation Nissan Xterra Forums (2005+)
Go Back   Second Generation Nissan Xterra Forums (2005+) > Xterra Tech Topics > Brakes, Tires and Wheels
Thread Tools Display Modes
  #1
Old 12-06-2006, 11:31 PM
dragonplayboy dragonplayboy is offline
Default What should I use to cover the holes in the soft 8's?
I'm getting ready to put on the black cragar soft 8's, and I want to put something over the roughly 3" hole in the middle of them, what should I use, what would be easy to obtain, what would be cheap/easy/look good?
thanks as always guys!
Old 12-07-2006, 05:48 AM
B Slater B Slater is offline
Default
Would a black spray paint top work??
__________________
Xterras freaking rule!
-05 OR (Sold)
-05 Ram 1500, LineX, 4.56 Gears, Detroit TrueTrac, Superchips, BFG AT's
-Looking for Xterra #3
  #3
Old 12-07-2006, 08:27 AM
Default
it might, but it would probably be dead obvious what it is... I'd like something flat maybe? Black plexiglass? I don't know...
  #4
Default
who would I call to get black plexiglass cut into perfect circles at a specified diameter?
  #5
Old 12-07-2006, 09:42 AM
Default
Quote:
I would call someone with a router....seriously.
  #6
Old 12-07-2006, 10:57 AM
Muzikman Muzikman is offline
Administrator
2005 Xterra Off-Road
Default
I am not even sure where you would find black plexiglass.
What about black dyed nylon plastic?
  #7
Old 12-07-2006, 11:24 AM
Alley Alley is offline
Noobie
Send a message via AIM to Alley Send a message via Yahoo to Alley
Default
If you want to do a plexiglass and you can find someone to cut it...since you have a non exposed side. Take limo tint and cover the non exposed side with the tint...that will give it the full black look.
__________________
~Danielle
  #8
Old 12-07-2006, 01:19 PM
lifeinthesouth's Avatar
lifeinthesouth lifeinthesouth is offline
2011 Had an '06 S now an '11 X
Default
That, or... just paint the non-exposed side black
__________________
--mike
The Grocerygetter!
  #9
Old 12-07-2006, 02:06 PM
Default
yeah, but I've seen black plexi before... maybe a sign vendor? I'd paint it before I'd tint it, way less hassle... but the plexi I'd never have to worry about the paint fading or chipping or anything like that.
  #10
Old 12-07-2006, 02:22 PM
Administrator
Default
What hole are you talkign about BTW? The hub?
You may not post new threads
You may not post replies
