metallic rattling sound during engine start - Second Generation Nissan Xterra Forums (2005+)
Go Back   Second Generation Nissan Xterra Forums (2005+) > Xterra Tech Topics > Powertrain & Driveline
Thread Tools Display Modes
  #1
Old 07-03-2008, 03:30 PM
2006xterrax 2006xterrax is offline
Member
Default metallic rattling sound during engine start
Very often during cold engine start, when engine revs up above 2K, there is a mattallic rattling sounds that comes out of the eingine. I suspect my timing chain is not tight enough. I talked to dealership, they said 'during engine start there is not oil for timing chain tensioners. but as soon as they are lubricated, it's lubricated'. or somthing like that. Bottom line is they said it's normal and nothing needs to b done.
Question - does that sound like a true/acceptable explanation to you? Or they simply do not want to perform a service on the truck.
Is it timing chain going out?
Thanks
Old 07-03-2008, 04:52 PM
Muzikman Muzikman is offline
2nd Godfather / Administrator
2005 Xterra Off-Road
Default
Timing chains have a very unique sound when they are going bad. Usually it's not a sound that you can hear though without close listening and/or a scope. If a timing chain was loud enough to hear at start up, I am sure it would have broke by now or at the very least jump some teeth and throw your timing way out.
Now...what about a fan belt pulley? A loose heat shield? Have you tried opening the hood and figure out where it is coming from?
I know the two times my alternator went bad it made a rattling sound.
__________________
Muzikman
www.thexterra.org
  #3
Old 07-03-2008, 05:49 PM
hybridpower's Avatar
hybridpower hybridpower is offline
Default
My timing chain tensioner was replaced under warrenty for exactly this; do a search, there is anouther longer post on this. Mine sounded like an aluminum rattle? I described it as "loudly banging two emply pop cans together!" No noises at all sense it was replaced.
__________________
05' OR, Night Armor
  #4
Old 07-03-2008, 06:40 PM
Member
Default
this thing sounds like if you take a metallic chain and drag it on a metal pipe, kind of like that. it lasts for less than 1 second, uusally when engine revs up above 2K.
  #5
Old 07-03-2008, 07:39 PM
Rmatzen's Avatar
Rmatzen Rmatzen is offline
2007 Xterra SE
Default
Is it like a buzzing/vibrating sound?
  #6
Old 07-04-2008, 11:50 AM
SVC707 SVC707 is offline
Send a message via AIM to SVC707 Send a message via Yahoo to SVC707
Default
if it goes away after one second that is the lack of oil at start up, now if you hear a whining sound which accelerates while reving you need to get the two secondary timing chain tensioners replaced. warranty is 5yr/60,000 and the dealership should have no problem accepting the job as i do it all the time, it can take a day or two to do depending on what time you drop it off.
__________________
2002 WS6: LME 408ci/D1 procharger 739hp/656tq 9/10psi 91 octane
Photo of car here: http://www.ls1tech.com/forums/showthread.php?t=603195
2006 Yukon Denali XL
2008 Xterra S 4x4: parts are building up waiting for installs
  #7
Old 07-04-2008, 12:32 PM
IZVERG's Avatar
IZVERG IZVERG is offline
2011 Magnetic Grey Metallic Tundra CrewMax TRD Off Road
Send a message via AIM to IZVERG Send a message via Yahoo to IZVERG
Default
Hmm, this sounds similar to my new start-up noise. It only lasts about 3 or 5 secs tops and then goes away. Like a rapid clicking sound, not sure what you mean by metallic noise though.
  #8
Old 07-05-2008, 03:44 AM
Rmatzen's Avatar
2007 Xterra SE
Default
mine happens when I accelerate after startup, its like a buzzing/vibrating/humming sound. I can feel it too.
  #9
Old 07-05-2008, 11:11 AM
Default
Quote:
what year is your vehicle, its possible that yours is indeed a timing chain
  #10
Old 07-05-2008, 04:06 PM
Rmatzen's Avatar
2007 Xterra SE
Default
Mine is a 2007.
You may not post new threads
You may not post replies
