Hey,
I have a 6spd man transmission and recently ive been getting a strange grinding noise. It happens in every gear after about 2500 rpm's. If i shift it goes away until, you guessed it, i hit 2500 RPM's again. does anyone know what it is?
Does it happen even when you're coasting at 2500RPM's? Is it worse when you give it gas? Could be something as simple as something rattling around somewhere...
where does it come from or seem to come from..how loud is it....many phones can now take sound clips...or video clips..can you upload one? it would help us diagnose your problem.....does the sound seem to come from a certain side of the truck...or the middle?
you may have a bad torque converter....however, this is incredibly rare on these trucks...
I had a rattle, seemed to be RPM specific - turned out to be a rock vibrating on top of the skid, easy fix. Hope yours is something as simple, seems like the above is a good lead.
yes i agree the above post sounds very promising....but if you could capture a video or sound clip of it..I'm sure somone on this site could give you a better idea of what it is.
Here's my two cents' worth. I also have a 6-speed, have heard a rattling noise while accelerating. Seems to go away if I just barely put pressure on the clutch pedal.
I think I've found a likely candidate. There is a pin that connects the clutch pedal lever to a clevis that most likely goes into the clutch master cylinder. (see arrow in pictures below)
When the clutch is fully released, there is no pressure on this pin. The holes in the pedal lever and clevis are slightly larger than the pin, which allows the pin to rattle.
The mechanism is set up this way so that there is zero pressure being applied from the clutch pedal to the clutch master cylinder when the clutch is released. Any residual pressure being applied could potentially cause clutch slippage, premature clutch wear, so on and so forth.
I don't think there's anything wrong with having the pin rattle, it's just annoying. That being said, I'm also trying to figure out how to get it to stop...
It seems to come from the middle. I'll try to upload a sound clip if I can capture it. It's subtle but if you drove the car every day or ride in it every day it becomes oh so prominent. It will annoy this $hit out of you. I'll check out that thread though Posted via Mobile Device
Yeah that thread exactly describes the Boise I'm getting. 2200 toms not when I'm in neutral. I'm going to check out the cure for it and see if it works for me too. I'll let y'all know. Posted via Mobile Device
Related Threads
1.6M posts
40.2K members
Since 2006
