How-to: Change the Thermostat - Page 2 - Second Generation Nissan Xterra Forums (2005+)
Go Back   Second Generation Nissan Xterra Forums (2005+) > Xterra Tech Topics > Powertrain & Driveline
Thread Tools Display Modes
  #11
Old 12-03-2012, 12:54 PM
snowtrout's Avatar
snowtrout snowtrout is offline
Veteran / (NWXC) Club Moderator
2012 Xterra Pro-4X
Default
Quote:
Originally Posted by masscomguru View Post
how does the computer know the thermostat is out? what was the code? I have never heard of that...
Since it does not appear this question was answered. In the generic OBDII codes (P0--- not P1---) there are at least 2 thermostat under temperature codes. Pretty much it means that the engine is taking too long to reach operating temperature or it never actually makes it to temp. Slight chance it could be a sensor or wiring issue but the bulk of the time it means that the thermostat is failed/failing.
Old 12-03-2012, 05:00 PM
Polar Bear's Avatar
Polar Bear Polar Bear is offline
Adventurer
2005 Polar Bear White Xterra SE
Default
Sweet man, glad that helped!! /
  #13
Old 12-03-2012, 10:07 PM
AZ-Ted's Avatar
AZ-Ted AZ-Ted is offline
2006 T-Swap Lightning Silver Xterra OR 4x4
Default
P0128 is a code for low coolant temperature. Many times this code will come on due to a faulty thermostat.
  #14
Old 12-09-2012, 08:07 PM
silverflash's Avatar
silverflash silverflash is offline
Default
as I don't have this code yet, but seem to be running a few degrees colder than i used to and it's taking longer to heat up, I will wait till after december 21st, just in case i screw the job up. Need my "get out of dodge and to the mountains" vehicle ready just in case!
__________________
2007 S 4x4 silver lightning- "BaseCamp" Edition
OEM fog lights,Nissan Bug Deflector,Nissan Seat covers,Trident white a/c unit mod
Rear Timbrens,Flexible mudflaps, GY DuraTrac 265/75R16 C-rated,bil 5100 shocks front/rear
K&N 57-6014 FIPK,Flowmaster 40/custom y-pipe, vistapro radiator, bully dog GT
  #15
Old 12-10-2012, 03:40 PM
Default
any issues when tightening or removing the 3 bolts that hold the t-stat on? Did you use a torque wrench and if you didn't is there room for one? i like to snug things down well but am heavy handed it seems and i think tighter is better when it's not and can break!
  #16
Old 12-11-2012, 01:30 AM
Polar Bear's Avatar
Adventurer
Default
Quote:
Good questions. As per our PM convo: I wasn't able to find anything on the torque specs for the bolts so I jst tightened them until I felt comfortable (not to break). Jst by feel, taking into consideration how tight they were when you unbolted them. I know it's hard to measure... But that's how I did it and it hasn't given me problems. I only used the gasket... From what I read/was told by the Nissan techs that's all you needed. Also, I didn't use a funnel. I did put a towel around the radiator so it wouldn't make a mess. This is important so you don't get the fluid all over the place (especially careful to not get any on your belts).
  #17
Old 12-11-2012, 02:15 AM
AZ-Ted's Avatar
Default
My FSM says 80 in-lbs for the thermostat housing bolts. That is not much torque at all.
  #18
Old 12-11-2012, 10:03 AM
Default
so my plan is to just finger tighten with socket and fingers then put put 1/4" ratchet on it and tighten bolts while holding the ratchet/socket near the junction of the socket and ratchet head until snug. That way, i should not get too much torque that would break a bolt...right?
  #19
Old 12-12-2012, 04:45 PM
Polar Bear's Avatar
Adventurer
Default
Yup, thats exactly what I did!!
  #20
Old 01-07-2013, 03:18 AM
salley1518's Avatar
salley1518 salley1518 is offline
2006 Xterra S
Default
I'm having a problem with the hot air inside the car, it never seems to blow hot unless i'm accelerating, even after driving for 20+ mins it still seems to blow cold air unless i'm accelerating from a stop, could this be a bad tstat?
__________________
Xterra, because the road to happiness isn't always a road.
You may not post new threads
You may not post replies
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Copyright 2006 - 2012, www.thenewx.org; www.thexterra.org
